EmbDev.net
Forum: PCB Design & Technology Gigabit Ethernet PHY Line Switching
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Egon (Guest)
Rate this post
useful
not useful
Hello,
I would like to use an 10/100/1000Mbps Ethernet transceiver for
switching between 1000Mbps Ethernet and 100Mbps Ethernet.
I am planning a redesign of an i.MX6 board which offers various
interfaces (I2C, SPI, USB, 100Mbps Ethernet, ...) over a 40-pin
connector to another board which has the magnetics and the connector for
Ethernet assembled.
During the redesign process Gigabit Ethernet shall be added (because the
processor can deliver it). However, I don't have enough lines left on
the connector to add this.
But on the new version the same 40-pin connector will get assembled a
second time (as an assembly variant) for optional additional interfaces.
This way the new version stays compatible to older boards. My idea was
that I will route the 4 differential pairs for Gigabit-Ethernet to the
new connector and the 2 already used pairs also to the old existing
connector. So these 2 pairs will get routed to both connectors. My idea
was to use 0 Ohm resistors to switch between the variants.
On the boards with the connector I would also use 0 Ohm resistors to
select the right mode and then route the differential pairs to the
magnetics and the RJ45 jack (maybe I will choose a RJ45 jack with
integrated magnetics).
This way I could stay compatible to already existing boards by using the
100Mbps.
And if 1000Mbps are wanted, I could assemble the new connector and
switch the 0 Ohm resistors to get Gigabit-Ethernet.
Do you understand my question or would a small sketch be helpful?
Do you think it could work this way? Do you think the 0 Ohm resistors
are a good idea or that this idea could work?
I am thankful for all input!
Cheers,
Egon
von Egon (Guest)
Rate this post
useful
not useful
Is it possible to just route the 2 additional Gigabit-Ethernet pairs to
the new connector? Then I would have 2 pairs routed on each connector.
Btw. you can also answer in German if you like. I just thought that I
would reach more people by posting on embdev.net but the German
community seems to be much active.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
