EmbDev.net
Forum: µC & Digital Electronics Arduino UNO as AVR Programmer (for Transistor Tester) under Linux
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Thierry R. (tyr)
Rate this post
useful
not useful
Hello,
Is it possible to use an Arduino UNO board as programmer for the AVR
toolchain under Linux ?
I have made few tests, everything goes well until "make upload" which
fails :
-> with the original ATMEGA328 from the Arduino board :
avrdude -c Arduino -B 5.0 -p m328p -P /dev/ttyACM0 \
  -U flash:w:./ComponentTester.hex:a -U eeprom:w:./ComponentTester.eep:a
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100%
0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be
performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "./ComponentTester.hex"
avrdude: input file ./ComponentTester.hex auto detected as Intel Hex
avrdude: writing flash (20220 bytes):
Writing | ################################################## | 100%
3.63s
avrdude: 20220 bytes of flash written
avrdude: verifying flash memory against ./ComponentTester.hex:
avrdude: load data flash data from input file ./ComponentTester.hex:
avrdude: input file ./ComponentTester.hex contains 20220 bytes
avrdude: reading on-chip flash data:
2.78s
avrdude: 608 bytes of eeprom written
avrdude: verifying eeprom memory against ./ComponentTester.eep:
avrdude: load data eeprom data from input file ./ComponentTester.eep:
avrdude: input file ./ComponentTester.eep auto detected as Intel Hex
avrdude: input file ./ComponentTester.eep contains 608 bytes
avrdude: reading on-chip eeprom data:
1.25s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x67 != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
avrdude done.  Thank you.
-> with a brand new (blank) ATMEGA328 :
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Thanks in advance for your feed-back
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
