EmbDev.net
Forum: ARM programming with GCC/GNU tools accessing crosscompiler
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von July J. (julyjim)
Rate this post
useful
not useful
This is very basic question
Optioning cross compiler / cross - linker  etc.
calls for "prefix" and I use arm-linux-gnueabihf-
OK - cross compiling between arm and linux.
The arm architecture is armhf etc.
In verbose output the "prefix" shows before gcc etc.
Now it ask for "PATH" apparently for the arm-linux-gnueabihf-.
I used /usr/bin/ and it works.
BUT it also works when I DO NOT SPECIFY the PATH.
Magic ? Or is there another parameter specifying the "PATH"?
Cheers
von N. G. (newgeneration)
Rate this post
useful
not useful
Hello,
I'm not sure if I understood you correctly.
You ask why you can execute the cross-compiler from the command line
without the full path to the compiler? This is because the shell
searches for executable binaries in the directories that are listed in
the environment variable PATH. You can view those directories using the
command
echo $PATH
If I misunderstood your question, then I'm sorry. Please speciefy your
question in this case.
Best regards,
N.G.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
