EmbDev.net
Forum: µC & Digital Electronics AVR USI TWI master/slave config
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Christoph L. (lehrlii)
Rate this post
useful
not useful
Hi folks,
I'm currently developing a sensor framework based on the TWI bus and I
use ATtiny85's as sensor nodes.
I want them to be able to communicate as TWI master, therefore I wanted
to implement the USI in TWI mode with Timer0 as clock.
So my questions are:
1. Do I have to use OCR0A or OCR0A?
2. When using Timer0, do I have to generate the clock manually or is it
done by the HW?
3. For bus arbitration I would need to detect if the bus is in use. Is
there a efficient way the detect stop conditions?
Unfortunately not even AVR believes in the USI interface and the whole
application notes depend on polling and the ATtiny85's datasheet is very
vague on this topic.
Thanks in advance.
von Hermann (Guest)
Rate this post
useful
not useful
You intend to make the I2C-communication by yourself? In this connection
I can't help.
I use Bascom and there is a library for master and slave which use the
USI-HW. I suppose a simular library is available in C. So you have
nothing to do with bits, clock and timer.
This is quite simple. To practice I have made a master which reads and
writes an EEPROM. And then I made a slave which emulates this EEPROM.
The only problem: the slave library costs about 14€ for all SW and HW
solutions.
If you are interested I can post the short source code.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
