EmbDev.net
Forum: FPGA, VHDL & Verilog if error on sequence detector
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rock B. (rocko445)
Rate this post
useful
not useful
Hello, i have the following error on every "if" and "case" line.
i am using quartus 2 'why i get these errors??
Thanks
Error (10500): VHDL syntax error at case_vhdl.vhd(19) near text "clk";
expecting "(", or "'", or "."
Error (10500): VHDL syntax error at case_vhdl.vhd(19) near text "and";
Error (10500): VHDL syntax error at case_vhdl.vhd(32) near text "else";
expecting "end", or "(", or an identifier ("else" is a reserved
keyword), or a sequential statement
Error (10500): VHDL syntax error at case_vhdl.vhd(40) near text "when";
expecting "end", or "(", or an identifier ("when" is a reserved
Error (10500): VHDL syntax error at case_vhdl.vhd(47) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(56) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(63) near text "when";
Error (10500): VHDL syntax error at case_vhdl.vhd(65) near text "case";
expecting "if"
Error (10500): VHDL syntax error at case_vhdl.vhd(70) near text "begin";
expecting ":=", or "<="
Error (10500): VHDL syntax error at case_vhdl.vhd(76) near text
"process";  expecting "if"
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity seqdeta is
 port (clk:in STD_LOGIC;
       clr:in STD_LOGIC;
     din:in STD_LOGIC;
     dout:in STD_LOGIC);
end seqdeta;
architecture seqdeta of seqdeta is
type state_type is (s0, s2, s3, s4);
signal present_state,next_state: state_type;
begin
 sreg: process(clk,clr)
 begin
        if clr='1' then
             present_state<=s0;
        elseif clk'event and clk='1' then
                present_state<=next_state;
         end if;
 end process;
23
24
 C1: process(present_state, din)
25
 begin
26
   case present_state is
27
       when s0=>
28
        if din='1' then
29
        next_state<=s1;
30
       else
31
         next_state<=s0;
32
      else if;
33
      when s1=>
34
        if din='1' then
35
          next_state<=s2;
36
       else
37
         next_state<=s0;
38
          end if;
39
40
      when s2=>
41
         if din='0' then
42
            next_state<=s3;
43
        else
44
           next_state<=s2;
45
           end if;
46
47
        when s3=>
48
         if din='1' then
49
            next_state<=s4;
50
        else
51
           next_state<=s0;
52
           end if;
53
54
55
56
        when s4=>
57
         if din='0' then
58
            next_state<=s0;
59
        else
60
           next_state<=s2;
61
           end if;
62
63
        when others =>
64
          null;
65
      end case;
66
67
     end process;
68
69
C2: process(present_state)
70
begin
71
   if present_state=s4 then
72
      dout<='1';
73
  else
74
      dout<='0';
75
  end if;
76
end process;
77
end seqdeta;
: Edited by Moderator
von Markus F. (mfro)
Rate this post
useful
not useful
Look very closely what you have written and where the first error
message appears, it's pretty easy to spot. Hint: you're missing a
termination at one of your if clauses...
Rate this post
useful
not useful
Hello , my first error is in the following "if" shown bellow
i used , end if , i ended every statement inside it with ";"
where did i go wrong?
if clr='1' then
             present_state<=s0;
end if;
Thanks
Rate this post
useful
not useful
check the same for your first case label.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Pls read and follow the instructions for the edit box. Here a shot
summary:
Reply
Rules — please read before posting
    Post long source code as attachment, not in the text
Formatting options
    [vhdl]VHDL code[/vhdl]
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
