EmbDev.net
Forum: FPGA, VHDL & Verilog Help in vhdl project
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Bozidar K. (teemo)
Rate this post
useful
not useful
I need some help in my VHDL project.
I need to write code for multiplexig 7 segment displays (4 of them) to
write 4 different characters.
After, I need to turn off/turn on all 4 7 segment displays every second.
(Blinking/flashing sign with always same letters).
I've done the multiplexing and on the Nexys3 board and got my text on 4
7 segment displays, but can't figure out how to turn on/off all displays
at same time with my text.
I got some kind of error: "Can't use Anode_Active same time in 2
processes".
Did anyone have a similar problem?
I appreciate any kind of help! <3
x7seg.txt --main code is here
x7seg_top.txt --just a top module
freqDivGen --clock division
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
> processes".
Yes, everybody who tries to assign a value to one and the same signal
from two processes.
Have a look for "multiple drivers vhdl" to find thousands of similar
problems...
BTW: pls attach *.vhdl files, not *.txt files. You will find some magic
named syntax highlighting... ?
: Edited by Moderator
Rate this post
useful
not useful
Meanwhile I had the time to peek into your code and one thing in
advance:
  if (temp>=nfCLK/2) then
    clk_o<=not clk_o;
This ist not the proper way to generate clocks in FPGAs. Have a look for
a strategy named "Clock Enable"...
When I synthesize those files with Xilinx ISE I get:
Process "Synthesize - XST" completed successfully
But the simulation shows: those two frequency dividers are working, but
nothing else is going on.
A closer look turns up: the counter led_activating is XX throughout
resulting in presenting the "when others" value at the "Anode_Active"
and "LED".
Try it with initializing the counter:
signal led_activating: std_logic_vector (1 downto 0) := "00";
Then the simulation runs like it should...
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
