EmbDev.net
Forum: µC & Digital Electronics Profibus Master
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Zen (Guest)
Rate this post
useful
not useful
Hi
There is a Profibus device DP-Slave (encoder), there is documentation on
it, but it describes in detail how to connect it to the PLC and how to
configure it using STEP7. I just need to connect it to the
microcontroller(Master-Slave)
Maybe someone has already written Master code or maybe there are
examples of data packets from master to slave with a description of the
whole procedure?
von Bastler (Guest)
Rate this post
useful
not useful
If you need a DP-Master with just one Slave, this is possible.
You need one timer and one UART.
I did this for testing DP-Slaves on a STM8.
I`ll send some documentation and examples when I´m at home.
Or maybe you can use a Master-Simulator?
There is a cheap one on eBay. It works like a RS232 to DP-Master
Gateway.
(B&N Elektronik Profibus DP Master Simulator)
von Zen (Guest)
Rate this post
useful
not useful
Thank you very much. I need just examples what I have to send to the
sensor
I googled about Profibus frame structure but it's not clear for I need
examples like
0x68 0x04 0x02 ...
where 0x68 is a start byte ...etc
von Ulrich K. (elektromechanikus)
Rate this post
useful
not useful
Hi Zen,
Profibus is not as easy as e.g. Modbus.
Your Master first reads the GSD file (kind of electronic data sheet) and
with the information contained there and additional parameters you may
enter ,then sends configuration data to your slave.
After that the master polls all connected devices (only one in your
case).
With different services the master now can read/write information
from/to the slave device.
You have to know the structure of the data within your Profibus slave
and the service to access them.
Without much deeper knowlege of Profibus, I don't think you will be able
to write your own communication interface.
I have attached screen shots from an old Profibus specification (it is
protected) which shall only indicate the complexity. The Profibus spec
is part of an international standard and thus no longer available for
free.
You should look at technology companies which offer solutions in
industrial communication (e.g. Hilscher, HMS, Molex). They have scalable
solutions from  code to chip to modules.
I have done internal Profibus certification for a couple of years but
all devices I have seen made use of a standard front-end from one of the
above mentioned companies.
wish you best luck with your Profibus
Ulrich
von Bastler (Guest)
Rate this post
useful
not useful
Sorry for the delay...
Her are some functions that may helpful.
von Zen (Guest)
Rate this post
useful
not useful
Thank you very much for this it's very helpful!
von Irshad (Guest)
Rate this post
useful
not useful
Sir
  If anyone  have example code of Profibus-DP Master code with single
slave, please share.I have slave example code. To test that I want a
Master Code.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
