EmbDev.net
Forum: µC & Digital Electronics Shift-In PCB to buy (e.g. using CD4021 or 74HC597) with Arduino Mega
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Walter H. (prefect62)
Rate this post
useful
not useful
Hi @ll,
I got an old railroad switchbox controlboard which originally was
connected to a heap of relays. I need to revive it using todays
electronics. At the moment I favor an Arduino ATmega for control.
The switchbox control has around 100 push-buttons that I have to read
in. No more than two push-buttons should be pressed simultaneously.
Question 1 - how would you do that?
I was thinking to use two or three chains of shift registers (the 4021
or 597 mentioned in the subject). I am not so much into soldering so I'd
prefer to use some well-designed prefabricated boards for the task
(instead of learning how to design PCBs myself, which might or might not
work out in time). But my search parameters did not find me anything
useful.
Question 2 - Do you know of such a PCB? Ideally it would be supplemented
by a library to adress it easily, but that is not a must.
Thanks in advance, Walter
von Thomas W. (diddl)
Rate this post
useful
not useful
I suggest a I2C IO board.
It is simple to build a chain of IO boards and it is simple to use with
an Arduino or a normal AVR board.
https://de.aliexpress.com/item/PCF8574-IO-Expansion-Board-I-O-Expander-I2C-Bus-Evaluation-Development-Module/32647794394.html
It costs 1€ per board
: Edited by User
Rate this post
useful
not useful
Rate this post
useful
not useful
Hi Thomas,
thank you so much for your answers! I will consider those boards that
you mentioned, the I2C looks tempting.
The only downside on those options is that they just provide 8
connections. The I2C board allows for 8 different adresses, so I would
need at least two separate buses to add up to my approximately 100 input
pins (2x8x8).
Therefore, if anyone can point me to an input board with even more pins
provided, I would be grateful!
Cheers, Walter
Rate this post
useful
not useful
Hi Walter
> connections.
Yes, this I2C boards are limited.
I've found two other boards with 16 x IO, but this is also insufficient
https://de.aliexpress.com/item/OPRN-SMART-PCF8575-IO-Expander-Module-I2C-to-16IO-I2C-to-16-bit-IO-expansion-breakout/32804822741.html
https://de.aliexpress.com/item/-/32859752451.html
So it would be the best choice this 595 board as suggested bevore:
https://de.aliexpress.com/item/74HC595-Shift-Register-Breakout-CJMCU-595-8-bit-shift-register/32807747744.html
Rate this post
useful
not useful
This one seems to have 3 address Pins so you can use 8 boards.
Each board has 16 IO.
And each IO can work as Input or Output (real GPIO).
And it costs only 80 Cent!
https://de.aliexpress.com/store/product/MCP23017-Serial-Interface-Module-IIC-I2C-SPI-MCP23S17-Bidirectional-16-Bit-I-O-Expander-Pins-10Mhz/716258_32828604912.html
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
