EmbDev.net
Forum: µC & Digital Electronics SWD for STM32F4VGT6
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rafael Bachmann (Guest)
Rate this post
useful
not useful
Hello,
I got a cheap barebones STM32F4VGT6 board, admittedly it was somewhat of
an impulse buy. It is made by diymore:
https://www.ebay.com/itm/STM32F407VGT6-ARM-Cortex-M4-32bit-MCU-Core-Development-Board-STM32F4Discovery-/311702413371
So far, I have used dfu-utils to burn my programs, which are generated
by STM32CubeMX. The dfu-utils method is described here:
https://github.com/dwelch67/black_pill_too
I would like to use a NUCLEO boards' SWD programmer to be able to debug
the MCU, but it does not break out the reset pin. Nonetheless, on the
back side silk screen it says:
SWD: PA13/DIO PA14/CLK
Do I have to pry the NRST line from the reset button, or can I use just
those 2 lines for SWD?
Thanks for your help.
von Christopher J. (christopher_j23)
Rate this post
useful
not useful
Those two pins are sufficient for SWD (together with a GND connection
obviously). You do not have to route the rst-Pin to your ST-Link unless
you e.g. want to do a "connect under reset" but you could also do that
manually by holding the reset button and releasing it after initiating
the debug connection.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
