EmbDev.net
Forum: Analog Circuits Convert Analogue DC to SENT
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Sergii (Guest)
Rate this post
useful
not useful
Hi, we have a task to convert Analogue DC signal (5V max) to SENT
protocol.
Therefore we are looking for AD converter with 2 Analogue inputs and one
Digital output.
Can someone advise any suitable options?
von derguteweka (Guest)
Rate this post
useful
not useful
Moin,
My knowledge of the SENT protocol is rather low, just what's on
wikipedia - but from that, i'm pretty sure, that an attiny13a should be
able to suit your needs.
BUT: looks like you'll need some real-time-assembler software writing
skills...
Gruss
WK
von Sergii L. (Company: TUM) (sergii)
Rate this post
useful
not useful
Servus WK,
should we keep it English, so that we can add some non-English speaking
guys in the discussion? =)
Yes, you are right, SENT is quite rare and basically used for automotive
sensor. Unfortunately, I have some basics skills of signal processing
only (mainly with LabView FPGA), so real-time-assembler sounds
frightening.
I made a brief research on the topic, do you think something like this
will suite the task? -> http://www.ti.com/product/ads8350
Rate this post
useful
not useful
Moin,
Looks like the ADS8350 is a dual channel ADC with SPI output. So you
might use it as an Analog-to-SPI Converter, but you'll still need
another chip to convert SPI to SENT. So this other chip would have to do
the "hard part" (the SENT timing, framing, calculation of checksums,
communication via SPI, etc).
Depending on your real needs, the ADS8350 might be even a little bit to
much - do you really need 16bit resolution at 750kSamples/sec with
simultaneous sampling?
Usually people asking for advice just believe they'd urgently need the
16bit resolution. But developing hardware to use the full 16bit range is
not at all a simple task. Layout recommendation in the datasheet is not
just because of the colorful pictures...
En plus: are you able to solder the itsy bitsy tiny 3x3mm 16pin package
with the exposed thermal pad?
Gruss
WK
von Anja (Guest)
Rate this post
useful
not useful
Hello,
usually SENT has 2 (main) channels with 12 Bit values so no need to use
a 16 Bit ADC. A ATTINY with 10 Bit ADC might be also not suitable.
Typical frame rate is around 1ms for the complete frame. So a few kS/s
will be sufficient.
I would use a PIC24FV32KA301/PIC16F184XX or similar with 12 Bit ADC for
this.
regards
Anja
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
