EmbDev.net
Forum: PCB Design & Technology Multi flex pcb stackup
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Roy (Guest)
Rate this post
useful
not useful
Is it ok to use adhesive and adhesiveless laminate in the same stackup?
von Georg (Guest)
Rate this post
useful
not useful
Obviously you should not have two layers without adhesive between them.
Georg
von Amit Bahl (Guest)
Rate this post
useful
not useful
Both are possible to implement separately in the design. However, it
won’t be possible to use them both in the same stack-up as per IPC
rules.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
