EmbDev.net
Forum: Off Topic Heidenhain TNC155A elctronic handwheel (HE-310)
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Jyrki K. (Company: none) (dzy)
Rate this post
useful
not useful
Hello,
I'm trying to implement something similar to this:
http://hsm-aktuell.de/cnc-hr330.htm
I've disassembled one EPROM from the TNC155A cnc controller that reads
the electronic handwheel but it's a bit tedious trying to figure out the
protocol from that. I've managed to find out the baud rate, number of
stop bits and parity settings from my disassembly and scoping the clk
signal on the TNC155A board.
Would anyone have some info on the protocol for the Heidenhain
electronic handwheel?
edit: Handwheel interfaces to the controller on the gfx board. There is
TMS9995 cpu and a TMS9902 serial interface device. INT1 is used for
character reception (5 bytes max or so it looks like)
INTR01 WP is at 0xdc00
INTR01 STCR *r1+,8
       SBO  18
       RTWP
From the disassembly listing I gathered that the serial interface runs
at 38400 baud, one stop bit, even parity and 8-bits of data (TMS9902
reset and setup code was easily found)
TMS9902RST LI   r12,>0000
           SBO  31
           LDCR @TMS9902_08,8
           SBZ  13
           LDCR @TMS9902_BC,12
           MOV  r12,@>dc18
           LI   r5,>0050
           LI   r1,>dc04
           MOV  r5,*r1+
           CLR  *r1+
           CLR  *r1+
           CLR  *r1+
           CLR  *r1+
           MOV  r5,*r1+
           CLR  *r1+
           CLR  *r1+
           CLR  *r1+
           CLR  *r1
           LI   r5,>dc05
           MOV  r5,@>dc02
           B    *r11
TMS9902_08 DATA >a300 ; TMS9902 %10100011 (1 stop bit even parity clk div by 3 8-bits) %00000000
24
TMS9902_BC DATA >000d ; TMS9902 LRDR register %00000000 %00001101 (((3MHz)/3)/13)/2 = 38461 baud
: Edited by User
Rate this post
useful
not useful
I managed to find out that the controller accepts PLC commands still
some things to figure out.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
