EmbDev.net
Forum: FPGA, VHDL & Verilog calculate power of float number
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Yusuf (Guest)
Rate this post
useful
not useful
I try to calculate y=2.5^x. y([0,2048)) is output which is 11 bits
positive int and x([0,8)) is 6 bit which will fixed-point with 3 digits
decimal and 3 digits fractional.
I write this module;
module prime(
    input [5:0] x,
    output [10:0] y
    assign y = ((5'b11001)/(4'b1010))**( x / (10'b1111101000));
endmodule
RTL scheme : https://hizliresim.com/1ploYN
But it did not work. Also, I upload RTL scheme, x is not attached.
What is the reason for this? Could not verilog make a calculation with
float numbers with this method?
von Svenska (Guest)
Rate this post
useful
not useful
Simply use a look-up table. Your 6 input bits result in 64 combinations,
which you can easily write down.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Yusuf wrote:
> Could not verilog make a calculation with float numbers with this
> method?
What says the manual of your specific toolchain?
And what result do you get in the simulation?
von Alexander (Guest)
Rate this post
useful
not useful
https://www.youtube.com/watch?v=0MUsVcYhERY
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
