EmbDev.net
Forum: FPGA, VHDL & Verilog VHDL Generic ADC SPI Controller
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Alexander S. (Company: Home) (alex_isr)
Rate this post
useful
not useful
Attached ModelSim VHDL design of Generic ADC SPI Controller.
Regards Alex.
Rate this post
useful
not useful
Design after repair SpiSync
 Regards Alex.
von -gb- (Guest)
Rate this post
useful
not useful
What do you mean with the word generic?
Which ADCs are supported? Is the SPI used to configure ADCs like AD9650?
What can be configured in your Code? Samplerate? Bits per Sample?
Aquisition Time? Daisy Chaining of ADCs like AD7902?
By now i wrote for most ADCs i used a individual HDL File to get the
optimal timing.
Rate this post
useful
not useful
Generic : Number of bits (resolution).
You also can select polarity of SpiClock and Spi Enable.
You can define Spi Slock not more than 1/4 System Clock By addition
clock.
One channel ADC without configuration commands.
 No !
 Currently I'm simulate other controller which can be used for multy
channel ADC or ADC with configuration commands
Rate this post
useful
not useful
-gb- wrote:
>  to get the optimal timing.
 What's optimal timing for you ?
Regards Alex.
: Edited by User
von Andreas S. (Company: Schweigstill IT) (schweigstill)
Rate this post
useful
not useful
> clock.
So this isn't a specialized SPI controller for ADC.
Great... this is the opposite of "generic".
>  No !
So it can only be used only for a very small subset of ADCs.
You are creating clock and synchronisation signals with both polarities
which is quite a bad idea. If an external differential signal is needed
it should be generated by the pin driver and not by the FPGA logic.
Rate this post
useful
not useful
 You need configurate output of FPGA such as differential outpet or use
external hardware differential driver.
 Regards Alex.
P.S.
 You can use or SpiClock or not SpiClock according to definition of ADC.
Rate this post
useful
not useful
 One Channel without external configuration ADC.
But it can be generated for 8,10,12,14,16 ... bits ADC with Spi Clock
different (more slowly) from system clock according to your applbcation.
 It's not small subset of ADCs in the SC70 package.
 Regards Alex.
Rate this post
useful
not useful
 See Test Bench
AdcSpiClock <= SpiSclk   when (SpiClockActive = '0') else nSpiSclk;
 For ADC I use only one of them according to ADC definifion.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
