EmbDev.net
Forum: PCB Design & Technology Repalcing a 3D model connector in Altium Designer
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Manjuh (Guest)
Rate this post
useful
not useful
Hello there,
I have got an old Project in Altium Designer where I have to make some
modifications. I would like to know the different steps to replace a
connector on the 3D model PcbDoc.
Something like having connector "A" from one manufacturer on the 3D Pcb
board and replace it with a connector "B" from another manufacturer.
Many thanks
von Wühlhase (Guest)
Rate this post
useful
not useful
1. Change the connector model in your footprint. Or make a new component
with the new connector.
2a. If you made a new component, replace the new component in
schematics. Then perform "import changes from schematics" into pcb.
2b. If you changes only your footpront, perform an "update from
libraries" command.
von Manjuh (Guest)
Rate this post
useful
not useful
> component
> libraries" command.
Hi Wuhlhase,
Thanks for the help. Since I am a newbie with Altium I have downloaded a
.step file of the new connector with the command place >> 3D Body I can
have the new 3D Body on the PCB board but I can't replace the old one
with this new one is there way to use this .stp file to make that
Change?
Thanks
Rate this post
useful
not useful
There are two options, but one is explicit NOT recommanded.
NOT recommand but the fastest way:
1. Break the old connector footprint with "Unlock primitives" command.
Attention: after this, you will move each primitive (pin, place print
lines and other) independet from the footprint. Be careful.
2. Remove the old model and insert the new.
The recommanded way:
1. Open your connector footprint and replace the 3D model.
2. Save your footprint.
3. Perform an update from libraries command.
von Manjuh (Guest)
Rate this post
useful
not useful
Hello Wuhlhase,
Thanks again for your help. I can't find the Footprint of the connector
to replace the 3D model for the recommended way.
You can have a look on my Attachement.
Is there any other way to do it?
Thanks
Rate this post
useful
not useful
Ok, you have to replace the component from a known library. If you hae
the two identical components from different libraries, there are two
different components for Altium. Try the following:
Make a library from your project (somewhere in design or tools menue.)
Install the library.
Your old footprint should be in the new library.
Now rework the footprint of your connector in the way I described above.
In your schematics editor, replace the old component with the new
footprint in schematics.
Perform an annotate schematics command. Recompile the project.
Now move to your pcb editor and perform an import from schematics
command.
Rate this post
useful
not useful
There is another thing: In the window in your atachement, you have to
select another library source.
Actually, you have selected the original source but this library is
unreachable for you.
If you try "Any", Altium will search any library. Better is, you
specifiy the library exactly with library path (selection point three).
von Maje L. (jaloten12)
Rate this post
useful
not useful
Changing the default altium library
(https://911electronic.com/best-professional-pcb-design-software-altium-vs-eagle/)
path also works
von Barkana A. (abdberkana)
Rate this post
useful
not useful
Had you been able to solve the problem of the connector ? If not you can
share your files and i can help you change it, or at least guide you on
how to change. If the footprint are the same you can go ahead and build
your pcb.
for suitable connectors you can check: (https://www.tmartis.com)
hope that may help
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
