EmbDev.net
Forum: PCB Design & Technology Help me with this robin subaru generator AVR
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Benjamin B. (benjamin1151)
Rate this post
useful
not useful
Can someone please help me reverse engineer this old (Robin subaru
generator avr) because i want to build the entire pcb, i already reverse
engineer the board with Sprint-Layout my problem is with some of the
components values used in the board?
von Einer (Guest)
Rate this post
useful
not useful
Which "some"?
Please take a better picture of the component side.
Rate this post
useful
not useful
im sorry sir my pcb is coated with epoxy i found this image online and
This is the image link
https://gw.alicdn.com/bao/uploaded/i3/T1lpNGFwxhXXXXXXXX_!!0-item_pic.jpg
I need to know the Zener values
Rate this post
useful
not useful
No one ?
von c-hater (Guest)
Rate this post
useful
not useful
> No one ?
What the fuck do you expect? We can't measure then Zener values, but you
can do it...
Remove the epoxy coating using a appropriate solvent, solder out the
Zeners and measure.
May be, you're a little bit more lazy than you should...
Rate this post
useful
not useful
I am here asking experienced people to help me if they can, I tried to
remove the items but it was broken and according to my research there is
no way to remove the glue.
And about being lazy, I am not an electronics engineer, and I already
get the values of some components but I am not 100% sure of the values
and I will upload the Image, In the end sorry for angering you.
: Edited by User
von Pawel N. (Company: {{{{{{) (pawel0777)
Rate this post
useful
not useful
hi,
Could you tell me if you managed to make this regulator? I also need
such a device but I can't find any source.
Rate this post
useful
not useful
I'm Sorry the generator is still parked in the garage
von pawel0777 (Guest)
Rate this post
useful
not useful
I used a universal AVR available on aliexp ... But the problem is that
this generator does not want to wake up itself. It can be done as an
additional coil used behind the cutter. Power connection from this coil
is on. Bridge rectifier for test procedure. Perform the function also
connected to the control function. During the under load tests, we
claimed that it was tested on a trial basis, and after firing it it woke
up with no problem.
Alternatively, excitation can be created by meticulous magnesia on
through as done in Chinese.
von Stefan (stefantheron)
Rate this post
useful
not useful
I've got an old Robin RGD 351, AVR is missing and I'd like to get a new
one. Have you been able to reverse engineer it? Maybe I could build one,
but it would be better to find one as I'm not too good with electronics
yet.
Thanks
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
