EmbDev.net
Forum: Analog Circuits vibration motor with laptop
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von dino_saur (Guest)
Rate this post
useful
not useful
Hello,
I want to connect a vibration motor (e.g.
https://paradisetronic.com/de/aktuatoren/mini-vibrationsmotor-1-5-5v) to
a laptop and control it with a software. The manufacturers of the
software suggest Chronos for this
(https://support.pstnet.com/hc/en-us/articles/115003480968-INFO-Chronos-and-Triggers-24492-).
I'm new to electronics and hardware, but I've tried to teach myself the
basics with Arduino :)
If I've understood it correctly, I need the I/O Cable and then use Pin 1
(+5V) for one cable of the vibration motor and Pin 5 (Analog Ground) for
the other one? Is it that simple or have I forgotten something?
Thank you in advance & regards!
von matzetronics (Guest)
Rate this post
useful
not useful
> the other one?
Note that even this little motor draws more current than the pin of the
Arduino can deliver. You need to add a driver transistor controlled by
the Arduino to drive the motor:
https://www.mikrocontroller.net/articles/Relais_mit_Logik_ansteuern
The 'Schaltstufe für kleine Lasten' is what you need.
Don't omit the Diode. Your motor is a inductive load like the relay and
needs the same circuit.
Rate this post
useful
not useful
Thank you!
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
