EmbDev.net
Forum: Analog Circuits 3S LiIon BMS ESP 32
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Max A. (max_mma)
Rate this post
useful
not useful
I am looking for a BMS for 3S Li Ion batteries. It should be designed to
protect against total discharge and
Short circuit and what else you need to protect. Also I want to
use my ESP 32 to query the charge status of the battery pack.
Unfortunately, I don't know whether a BMS is also there to charge the
batteries and whether you need battery balancing. I am brand new to this
topic and glad about tips and board suggestions from you guys
looking forward
greetings
Max
von matzetronics (Guest)
Rate this post
useful
not useful
Depending on your affinity to dumpster diving I'd go for a readymade
11.1V battery pack from a notebook. They contain over- and undervoltage
protection and a controller which you can query using SMBus - a slower
version of I²C bus.
The cells are already selected for equal performance so you could spare
the balancing and charging is done via a constant-current first,
constant voltage later circuit for 12.6V nominal charging voltage.
Thy can also deliver high currents in case you need them.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
