EmbDev.net
Forum: µC & Digital Electronics Upload code to atmega328p
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lernend B. (Company: KUKE Electronics CO., Limited) (lernend05)
Rate this post
useful
not useful
I want to design atmega328p (referenced data source:
https://www.apogeeweb.net/circuitry/atmega328p-microcontroller-datasheet-pinout-circuit.html)
on PCB...
One method to upload code is using Arduino Uno. If I disconnect the
wires from arduino uno side but left them in atmega328p side, will be
there any problem such as open circuit because of wires?
My idea is to solder the wires in PCB and when I need to upload code or
monitor data I connect these wires to arduino uno.
Is there anyone have ideas of it?
: Moved by Moderator
von MaWin (Guest)
Rate this post
useful
not useful
Lernend B. wrote:
> uno side but left them in atmega328p side, will be there any problem
No, but your ATmega328 needs to be preprogrammed with the Arduino
bootloader, so either pulled off an arduino board or programmed with the
bootloader code using some other method, like the native MISO, MOSI,
SCLK, RESET Interface. And if you can program an ATmega328 using this
method, why not use it for the real program and skip the Arduino
completley.
von stefanus (Guest)
Rate this post
useful
not useful
Open wires have an impact if you use the same I/O pins for other
communication, e.g. a display with SPI interface. It depends on the
length of wires and the amount of radio waves in the area.
For development phase on the desktop this is usually no problem,
specially if the wires are as short as 30cm .
Rate this post
useful
not useful
The I²C is much more affected because is has weaker pull-up resistors
compared to the active HIGH level driven by I/O pins. But even I²C does
usually work fine with short open wires.
von Banana (Guest)
Rate this post
useful
not useful
ISPC - In Circuit Serial Programming is meant for exactly that.
Arduinos for example are build that way, these connections stay after
programming.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
