EmbDev.net
Forum: Analog Circuits Applications where a transimpedance amplifier is used for measuring small sine AC currents.
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Ron (Guest)
Rate this post
useful
not useful
Dear all,
for a thesis I'm looking for applications where a transimpedance
amplifier is used for measuring a small sine wave current (AC current).
Means on the non inverting input of the transimpedance amplifier (TIA) a
reference sine signal is conneted. On the inverting input a sensor is
connected. As soon as the sensor draws a current this current leads to a
change in voltage of the TIA output.
I would be very glad when you could send me examples where a wiring like
this is realized.
Kind Regards
Ron
: Moved by Moderator
von diffout (Guest)
Rate this post
useful
not useful
You noticed that applying a voltage to the noninverting input will
either change the voltage across the sensor accordingly or (if that’s
not possible) force the output of the TIA into one of its rails? I
couldn’t imagine why you would use such a measurement setup on a DUT.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
