EmbDev.net
Forum: Analog Circuits Dual supply with current limit
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von giselach (Guest)
Rate this post
useful
not useful
Hey,
I need a dual power supply for experiments with opamps. In order to not
blow up my circuits too early I'd like to have some way to adjust a
current limit.
The LM317 (and LM337) datasheet shows a current limiting application
using a resistor from output to adjust pin. Based on that I also found
the following circuit, which seems to serve my purpose pretty nicely:
https://www.eeweb.com/adjustable-current-limit-for-dual-power-supply/
The thing is, that the current sensing resistor (as they call it) at the
output of the regulator gets the total current. That requires a special
low value, high power part that I don't have in my collection and that
seems bulky and expensive.
Can someone point me to alternative designs that don't require power
resistors and are still similarly simple?
von MaWin (Guest)
Rate this post
useful
not useful
giselach wrote:
> That requires a special low value, high power part that I don't have in
> my collection
That's life.
Connect a few that you have in parallel to solve that problem.
Every other circuit will also have a problem that you don't have all the
parts, and as you are too lazy to buy anything, there will be no
solution.
I don't like your current limiting circuit, but an LM3080 will not help.
von Dieter (Guest)
Rate this post
useful
not useful
Tell first how exact this has to be. In case of smooth limits enough you
should try current mirrors with simple power transistors.
Study this carefully:
https://wiki.analog.com/university/courses/electronics/text/chapter-11
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
