EmbDev.net
Forum: µC & Digital Electronics STM32H7 bank swap break at address 0x81006fe
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Fabian (Guest)
Rate this post
useful
not useful
I trying to do a bank swap with the ST32 H743ZI2. I wasted much of time
to fix it but i didnt get it. Maybe because im new in STM32 controllers.
I copied the bank swap code from STM32CubeH7 Firmware Examples and did a
few modifications regarding to gpio configuration in CubeMX. I did them
because i want to implicate the code in a excisting project without the
stm32h7xx_nucleo headers.
Following the Code for Bank1:
HAL_FLASH_Unlock();
HAL_FLASH_OB_Unlock();
while (1)
    /* Wait for BUTTON_USER is released */
    if (HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_13) == 1)
  while (HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_13) == 1);
  /* Get the Dual boot configuration status */
  HAL_FLASHEx_OBGetConfig(&OBInit);
  /* Get FLASH_WRP_SECTORS write protection status */
  OBInit.Banks     = FLASH_BANK_1;
  /* Check Swap FLASH banks  status */
  if ((OBInit.USERConfig & OB_SWAP_BANK_ENABLE) == OB_SWAP_BANK_DISABLE)
    /*Swap to bank2 */
    /*Set OB SWAP_BANK_OPT to swap Bank2*/
23
    OBInit.OptionType = OPTIONBYTE_USER;
24
    OBInit.USERType   = OB_USER_SWAP_BANK;
25
    OBInit.USERConfig = OB_SWAP_BANK_ENABLE;
26
    HAL_FLASHEx_OBProgram(&OBInit);
27
28
    /* Launch Option bytes loading */
29
    HAL_FLASH_OB_Launch();
30
31
32
      as the  CPU is executing from the FLASH Bank1, and the I-Cache is enabled :
33
      Instruction cache must be invalidated after bank switching to ensure that
34
      CPU will fetch correct instructions from the FLASH.
35
36
    SCB_InvalidateICache();
37
38
39
    HAL_NVIC_SystemReset();
40
41
  else
42
43
    /* Swap to bank1 */
44
    /*Set OB SWAP_BANK_OPT to swap Bank1*/
45
46
47
    OBInit.USERConfig = OB_SWAP_BANK_DISABLE;
48
49
50
51
52
53
54
55
56
57
58
59
60
61
else
62
63
#ifdef FLASH_BANK1
64
    /* Toggle LED1 */
65
66
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
67
/*Turn Off LED2*/
68
HAL_GPIO_WritePin(GPIOE, GPIO_PIN_1, 0);
69
70
#else
71
      /* Toggle LED2 */
72
    HAL_GPIO_TogglePin(GPIOE, GPIO_PIN_1);
73
      /* Turn off LED1 */
74
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, 0);
75
#endif
76
77
  /* Insert 100 ms delay */
78
  HAL_Delay(100);
79
80
81
/* USER CODE END WHILE */
82
83
  /* USER CODE BEGIN 3 */
84
85
  /* USER CODE END 3 */
86
The code for bank1 and bank2 are equal except linkerscript. I splited
Flash in two areas wich have 1024kb each. In following you can see the
code for bank1.
/* Specify the memory areas */
MEMORY
  RAM (xrw)      : ORIGIN = 0x20000000, LENGTH = 128K
  RAM_D1 (xrw)   : ORIGIN = 0x24000000, LENGTH = 512K
  RAM_D2 (xrw)   : ORIGIN = 0x30000000, LENGTH = 288K
  RAM_D3 (xrw)   : ORIGIN = 0x38000000, LENGTH = 64K
  ITCMRAM (xrw)  : ORIGIN = 0x00000000, LENGTH = 64K
  FLASH (rx)     : ORIGIN = 0x8000000, LENGTH = 1024K
In linkerscript for bank2 i changed flash start addres to 0x08100000.
Now i have following problem. If i load in order code for bank1 and code
for bank2 press the Button1 and Press the Resetbutton i get following
error message:
Break at address "0x81006fe" with no debug information available, or outside of program code.
I already successfully checked if there is placed some code with STM32
Utility.
If i load the codes in reverse order the banks get swaped once.
Independently if Button1 gets pressed before system reset or not..
I already checked some forums without success.
Does anyone know where the problem could be?
von erklehr behr (Guest)
Rate this post
useful
not useful
The main problem is that you aren't willing to follow the
rules for posting program code.
So I'm not willing to really look at your problem ....
von Fabian K. (scheinwerfer)
Rate this post
useful
not useful
You mean because it´s a long code? Sorry didnt know that 90 lines are to
long..
Rules violation wasnt my intention. I tried to edit the post
unfortunately there are problems with my email host so i didnt get some
mail from embdev.net or microcontoller.net. I would do a new post but i
thinks its against the rules too.
As soon as i can edit the post i will do it.
Maybe you can forgive this serious mistake. In case you did the code in
question and the complete code is in attachment.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
