EmbDev.net
Forum: Analog Circuits Stepdowns in parallel
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Max A. (max_mma)
Rate this post
useful
not useful
Hi
I have read in some forums that you should not close stepdowns in
parallel without certain safeguards. In my project I have a Raspberry Pi
that controls servomotors. These pull so much that a 9A stepdown is not
enough. Now I plan to connect several small stepdowns (XL 4015) in
parallel to my LI ION battery block with BMS. Each stepdown then
supplies 3 servomotors. I have a total of 18 servos, so 6 stepdowns.
Is that possible without causing any damage or the like?
I am very happy to receive an answer
Kind regards Max
: Moved by Moderator
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
No, because you do not use them in parallel at the output side. Just
beware that you must connect all of them GND together.
> that a 9A stepdown is not enough.
If these are the usual 9 Chinese Ampere, then divide this value by 5 to
get Real World Amperes.
: Edited by Moderator
von foobar (Guest)
Rate this post
useful
not useful
> you should not close stepdowns in parallel without certain safeguards.
That's about the outputs.  In your case only the inputs are connected
which is fine.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
