EmbDev.net
Forum: Analog Circuits Do control signals between digital and analog circuits need to be isolated?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Cliff W. (cliff)
Rate this post
useful
not useful
Does the control signal from the digital section output to the analog
section need to be isolated? The analog section requires a voltage
ripple level of uV.
von Jochen der Rochen (Guest)
Rate this post
useful
not useful
Depends on the signal and application.
How often does this control signal change?
Which analog signal should not ripple?
How far away is it placed on your board from your analog signal, which
is not allowed to have much ripple?
Are there ground planes placed in between?
How is your layer setup for the board?
These are all questions which come into play here.
Rate this post
useful
not useful
Thanks for your reply, I decided to add an optoelectronic isolator.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
