EmbDev.net
Forum: µC & Digital Electronics How to solve the AVR microcontroller fuse bit lock-up problem
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Cliff W. (cliff)
Rate this post
useful
not useful
How to solve the AVR microcontroller fuse bit lock-up problem?
von matzetronics (Guest)
Rate this post
useful
not useful
Erasing the entire chip will also reset the fuses.
von Axel S. (a-za-z0-9)
Rate this post
useful
not useful
Depends on what exactly is the problem.
There is no single "the fuse bit lock-up problem".
Clock Fuses? → use external clock
Reset redefined as debugWire? → attach debugger
Reset disabled? → HV programmer needed
A simple one-fits-all solution can be found by googling for "fuse
resetter" or "fuse doctor". This is a one-purpose HV programmer that
issues a chip-erase.
von EAF (Guest)
Rate this post
useful
not useful
No!
Only the lock Bits.
Only High Voltage Programming can fix all Fuse Problems.
von stefanus (Guest)
Rate this post
useful
not useful
Think twice before clicking on the start button.
All other solutions cost more than they are worth. Unless you are so
stupid to repeat the same mistake dozens of times.
Rate this post
useful
not useful
I assume that TO means situations where he locked himself out, so he
cannot erase the chip anymore.
von ... (Guest)
Rate this post
useful
not useful
With a parallel programmer there is no lockout problem.
You get what you pay for.
Rate this post
useful
not useful
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
