EmbDev.net
Forum: ARM programming with GCC/GNU tools Quadruple Half-H Drivers
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von L293DNE Quadruple Half-H Drivers (Guest)
Rate this post
useful
not useful
The L293 and L293D are high-current quadruple half-H drivers. These
devices are intended to power a variety of inductive loads, including
relays, solenoids, DC and bipolar stepping motors, and other
high-current and high-voltage loads. All inputs are TTL compatible and
can withstand voltages of up to 7 V. Each output is an entire totem-pole
drive circuit, complete with a Darlington transistor sink and a
pseudo-Darlington source. Drivers are enabled in pairs, with 1,2EN
enabling drivers 1 and 2 and 3,4EN enabling drivers 3 and 4.
I have learned L293DNE from this article:
https://www.apogeeweb.net/circuitry/l293dne-quadruple-half-h-drivers-datasheet-arduino-pinout.html
If you get more ideas, please tell me.
von Tilo R (Guest)
Rate this post
useful
not useful
IC from the last century.
Using bipolar darlington as drivers, the IC typically loses 1,4V at the
highside and 1.2V at the lowside.
If you e.g. want to drive a 12V-Motor, a 12V-Power-supply will result in
only 9.4V at the motor.
Modern ICs have lower losses and allow for higher currents at comparable
prices. Additionally, many of them have open-loop detection or
overcurrent-protection.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
