EmbDev.net
Forum: µC & Digital Electronics How To Flash NOR-Flash MX25U128 From MXIC
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Andreas B. (a_ndreas)
Rate this post
useful
not useful
Hello Forum
long story short, yesterday i bricked my Mini-PC while flashing the
BIOS. Now I have learned that an MXIC (MX25U12873F) 1.8V, 128M-BIT [x
1/x 2/x 4] CMOS MXSMIO  (SERIAL MULTI I/O) FLASH MEMORY is used to store
the BIOS.
I cant find any valuable information on how to flash the IC -the right-
way. The IC is an 8-pin SOP soldered on board. I have the image file but
no clue to flash the IC.
I whish to reprogram the IC using the BIOS image provided, in hopes to
revive the mini-pc.
The manufacturers data-sheet can be found here:
https://www.mxic.com.tw/en-us/products/NOR-Flash/Serial-NOR-Flash/Pages/spec.aspx?p=MX25U12873F&m=Serial%20NOR%20Flash&n=PM2348#Technical-Documents
I tried hard on ebay and amazon to find a suitable Serial EEPROM & FLASH
PROGRAMMER for this specific IC from MXIC but im not sure which
programmer is to pick.
any help appreciated
thanks in advance
Andreas
von A. B. (Guest)
Rate this post
useful
not useful
That's a rather standard SPI flash, so almost all programmers available
for SPI flash devices will do - except it's 1.8V only, so you have to
look for a programmer supporting that supply level.
Another option is to get a Nucleo-Board with 1.8V option like
Nucleo-H7A3ZI-Q, -H723ZG, -H743ZI2, jumper it to VDD 1.8V and use to use
OpenOCD with QSPI driver (built in on recent versions) or with patch
https://review.openocd.org/c/openocd/+/4760.
The main obstacle in both cases is to remove the chip from the
mainboard, attach it to the programmer (by a test socket) and later
solder it to the mainboard again. That's not trivial if you don't have
some experience in (de-) soldering. To program it on the mainboard is
possible theoretically but requires some precautions (keeping the
mainboard's connections in high-impedance state etc.)
So, it boild downs to this rather mechanical issue ... Do you have any
experience regarding that? If not, the question regarding a programmer
is rather pointless, I'm afraid.
von john mil's (Guest)
Rate this post
useful
not useful
i having problems with my motherboard. it runs very slow. and i try to
update it. i use bios flash. and it installs corectly.. sadenly.. arter
the restart my board wont display anymore... what im ganna do?? my
motherboad is A320M PRO-VH PLUS.. MY PROCESSOR IS AMD A6 9500 series..
its no use anymore.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
