EmbDev.net
Forum: µC & Digital Electronics STM32 ADC & DMA corrupted Values
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rebell (Guest)
Rate this post
useful
not useful
Hi Forum
I use adc with dma on different stm32-mcus.
i try to sample 3 channels in continous mode with a long buffer to
filter later.
this all works as long as there is no additional interrupt.
i set up the system with highest priority for dma(0), but lowesd for
I2c(3) in NVIC.
What happens:
the order of the adc values in Memory changes for no reason.
Value 1 -> Battery Voltage -> adcRawMemory[0]
Value 2 -> External Poti -> adcRawMemory[1]
Value 3 -> Temperature -> adcRawMemory[2]
Value 1 -> Battery Voltage -> adcRawMemory[3]
Value 2 -> External Poti -> adcRawMemory[4]
Value 3 -> Temperature -> adcRawMemory[5]
after some intterupts on i2c the order changes:
Value 1 -> Battery Voltage -> adcRawMemory[1]
Value 2 -> External Poti -> adcRawMemory[2]
Value 3 -> Temperature -> adcRawMemory[3]
Value 1 -> Battery Voltage -> adcRawMemory[4]
Value 2 -> External Poti -> adcRawMemory[5]
Value 3 -> Temperature -> adcRawMemory[6]
I also see this behavior with the iwd activated...
any one has some fundametal hints to this problem?
Is there any syncronisation issue in the stm32 core that needs to be
addressd when using ADC with DMA?
Rebell
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
How long is your "adcRawMemory" buffer? Does it "wrap around"
autmatically?
Did an error occur on the I2C bus meanwhile?
von stefanus (Guest)
Rate this post
useful
not useful
Are you using an STMF103C8xx or STM32F103CBxx? I am asking because the
web is full of negative reports about fake products with wrong data
transferred by DMA.
von Rebell (Guest)
Rate this post
useful
not useful
> autmatically?
Hi Lothar
adcRawMemory is 288 Bytes and im sampling 6 channels.
I2C Bus error could happen ... i have to check. whats the outcome if
there is an error?
>transferred by DMA.
the mcus are from the STM32F0xx and STM32G4xx Family. they should be
genuine, they ar from the time bevor the chipcrisis :-)
thanks, Rebell
von Rebell (Guest)
Rate this post
useful
not useful
i just checked i2c ...
no error on bus when the missalignment is happening ...
Rebell
Rate this post
useful
not useful
Rebell wrote:
> whats the outcome if there is an error?
That depends on how you have configured the reaction to such problems.
Maybe no data is written and so the next AD values move up one
position...
von Rebell (Guest)
Rate this post
useful
not useful
So what can cause such a "moving"?
ADC and DMA should be independent to any other CPU-driven actions right?
only the DMA can stopp the CPU from accessing the same BUS at the same
Time when DMA is writing the Values to Mamory.
how can a CPU-driven action compromise the DMA-Pointer or the ADC
Channel selsction? (of corse without writing to this specific registers
Rebell
von Rebell (Guest)
Rate this post
useful
not useful
So my guess is:
dma uses the the APB bus for Transfering ADC Values to Memory.
When an I2C-Interrupt occures the APB Bus may be accessed from CPU and
therfore an access fom DMA is not possible or delayed.
whats the access priority here? i'm not to deep into the architecture
from STM here...
could the source of this problem a timing issue on the Bus be?
Rebell
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
