EmbDev.net
Forum: Analog Circuits How to adjust RC oscillator circuit frequency?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lernend B. (Company: KUKE Electronics CO., Limited) (lernend05)
Rate this post
useful
not useful
Hello folks,
Recently I am working on RC oscillator circuit according to here
(source:
https://www.kynix.com/Blog/What-are-Oscillator-Types-Example-with-Diagrams.html),
but I had problems with adjusting frequency. I can adjust frequency but
it effects amplitude too (amplitude is changing while adjusting
frequency), how can i separate these two variables ? I mean, when I am
adjusting frequency, I want to amplitude remains same, and also for
amplitude too. By the way I am using this circuit: (Ignore the opamp
circuit, it is converting sinusoidal wave into square wave.)
Any idea of it? Thank you in advance.
von Cartman (Guest)
Rate this post
useful
not useful
Thats quite easy.
Use a ceramic adjustment tool for the frequency and
another tool for the voltage.
Determine the correlation between frequency change and
voltage change vs. voltage control and frequency control.
With this you will be able to adjust your circuitry to
the final values in one step.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Lernend B. wrote:
> I can adjust frequency but it effects amplitude too (amplitude is changing
> while adjusting frequency), how can i separate these two variables ?
Simple answer: you can't.
Or a little bit longer: you can, but you must add much more parts into
your schematic to keep the oscillator sinusodial AND to stabilize the
amplitude of the output signal.
So the first step is: generate a sine signal.
Second step is:  stabilize it to a stable amplitude.
And the last step is: amplify it to the desired output swing.
Thats why real world signal generators are more expensive compared to
some C, R and a transistor.
> Any idea of it?
Whats the actual problem?
: Edited by Moderator
von Lutz V. (lvw)
Rate this post
useful
not useful
Lernend B. wrote:
> Hello folks,
> (source:
I think, for a real helpful answer, we need some more information:
* What is the required tuning range (frequency)?
* What is the required amplitude range?
* Is it allowed to vary two components in parallel?
* Are you required to use the shown circuitry (phase shift principle
with a BJT)?
You should know that there are many different and versatile oscillator
circuits (more than mentioned in the referenced paper), which - probably
- are more suitable for your needs....
: Edited by User
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
