EmbDev.net
Forum: Analog Circuits Induction-Heating-Circuit not drawing any Current
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Joel (Guest)
Rate this post
useful
not useful
Hey,
I've tried to build an Induction-heating-circuit, but it doesnt draw any
current from my adjustable Transformer, no matter which voltage i give
it. I planned to run it from mains-voltage(230V-50Hz). The Inductance of
my Work-coil is around 100µH, the Work-Cap is around 330nF which gives
me a resonant frequency of 28500hz. I adjusted my Driver-IC to output me
this, and it works great. But my adjustable Transformer just shows me 0A
current. I am sure that this measurement is right, because the IGBTs
also dont get hot. Please help me!
von Hermann S. (Guest)
Rate this post
useful
not useful
I think you dont need L1 and L2...only the work coil and the resonant
tank cap in series or parallel. You have a series oscillatinc circuit.
Rate this post
useful
not useful
the gate resistors are a bit too high...acc. to the datasheet, they use
a 10 Ohm Gate resistor for the given switching times. I also suggest to
use a gate driver with more power, 160 mA is too less. You want to
switch the IGBT´s fast which results in less switching losses for
IGBT´s.
For my induction heater, i use a STM32 for controlling and a MCP14E10
for gate driving with a GDT. The MCP14E10 can deliver up to 3 A.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Joel wrote:
> But my adjustable Transformer just shows me 0A current.
With what load? Where should the energy go to?
Rate this post
useful
not useful
The energy will wasted in the LC circuit with no load (iron, etc.) in
the coil.
Rate this post
useful
not useful
at idle (no load in the coil) and control with resonant frequency, a
series resonant circuit pulls the most power, where a parallel resonant
circuit will pull at least power at resonant frequency.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
