EmbDev.net
Forum: FPGA, VHDL & Verilog Low Frequency PLL for FPGAs and CPLDs
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Joseph Kosednar (Guest)
Rate this post
useful
not useful
Hello,
I would like to know if anyone needs a Low Frequency Multiplying Phase
Locked Loop for their FPGA, CPLD designs with the following specs:
1.  Instant lock
2.  Small foot print
3.  2ns lock to leading edge
4.  10 bit multiplier value
5.  Clock in frequency = don't care
6.  Clock in frequency around 12MHz
7.  Input sample frequency 10Hz to 1000Hz auto ranging
8.  Stable
9.  Jitter -2ns
10. Generates LOCKED and OVERFLOW
If you could use this IP please let me know and how would you use it?
von Andreas (Guest)
Rate this post
useful
not useful
Hi Joseph,
release on opencores.org or github and look what happends :)
BR,
Andreas
von Torftroll (Guest)
Rate this post
useful
not useful
Jitter .. 2ns .. what ?
von mercatore (Guest)
Rate this post
useful
not useful
The 2ns jitter seem to be the result of a sampled edge with a self
running clock at 500MHz, which is a typical clock frequency of such self
running clocks. Well this is much to much for a typical FPGA app.
Generally I wonder for which kind of apps this solution might by
appropriate:
Typically one will use any internal pll in an FPGA and use feedback
loops to adjust to an incoming low frequent clock signal. This way one
can adapt to signals of around 1/50 of the system pll clock, e.g. 20MHz
internal and 500kHz external with less than 100ps.
Also todays FPGA PLLs are tolerant downwards to 5MHz using non phase
locked operation mode (DCM only), and 15MHz in phase locked operation
mode.
On the other hand clock frequencies below 10MHz are not appropriate for
high speed designs since the incoming jitter is already too high. This
is the reason why we use at least 100MHz RefClk for e.g. DDR RAM
designs.
If one uses around 1MHz input osc frequency for instance, one will have
to accept at least 1ns jitter because of the mitigation ratio of 2:1
limiting the subsequent circuits jitter budget to 100MHz. Using a common
PLL with an appropriately selected division ratio coming close to the
input and using phase loop.
So I do not see the reason for a complex digital PLL to derive internal
system clock frequencies.
Rate this post
useful
not useful
Well, you have a clock of 10MHz and can run the FPGA internally with
200MHz. Then I guess, you don't have this jitter.
Rate this post
useful
not useful
My low frequency pll for use in VLSI devices uses a sysclk of 6 to 16MHz
(tested).  The leading edge of the pll input frequency is locked to the
leading edge of the output frequency with a gate delay of two.
For further specs see my patent #11290117 or contact me.  I would be
glad to discuss what my LFPLL can do.
von kosednar@yahoo.com (Guest)
Rate this post
useful
not useful
> appropriate:
> mode.
> designs.
My invention was developed for use on the design of a digital speed
controller.  I was interested in characterizing a motor driven by a
pass-drive IGBT.
My interest was graphing the power of the motor firing the IGBT at fixed
angles.  My invention works great in this application.
I use a SYSCLK of 10 to 20MHz so my delta time is 50 ns which is
undetectable when you are looking at low power frequencies i.e. 50/60Hz.
The two gate delay jitter is the time between the leading edge of the
input frequency and the leading edge of the output frequency.
I'm aware that today's FPGA's Pll must operate at or above 5MHz.  That
is precisely why I developed my Low Frequency PLL.
I'm not interested in High-frequency design for my application.  I'm not
the only VLSI designer that can use my design.
Rate this post
useful
not useful
> appropriate:
> mode.
> designs.
pass-drive IGBT.
> with 200MHz. Then I guess, you don't have this jitter.
My design is an arithmetic design.  The operation is nothing like
standard PLLs today.  The result is similar to analog PLL's found on the
shelf today.
If you wish to understand my design, check out patent US 11,290,117 or
contact me and I will explain my design.
Andreas wrote:
> Hi Joseph,
> BR,
> Andreas
Andreas,
Thanks for the open source possibility ideal but my plans aren't headed
in that direction.
I'm using my design in a specialized motor controller and will enjoy the
protection of the design that my patent affords me.
Joe
Rate this post
useful
not useful
50ps
von Mark W. (Company: SKM Instruments) (markw307)
Rate this post
useful
not useful
Yes, I am interested. This may be helpful for generating trigger pulses
off of the reference laser in an FT NIR spectrometer.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
