EmbDev.net
Forum: Analog Circuits Small BMS for Li-Po
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Theliadir T. (theliadir)
Rate this post
useful
not useful
Hello
I am building a small electronics project.
In it I want to use a rechargeable Li-Po battery.
I use this Li-Po:
https://de.aliexpress.com/item/32770011525.html?gatewayAdapt=glo2deu&spm=a2g0o.order_list.0.0.21ef5c5feYh48G
Now I am looking for a battery management system.
My project is quite small, so I also need a BMS as small as possible. I
found this module.
https://de.aliexpress.com/item/33050079276.html?gatewayAdapt=glo2deu&spm=a2g0o.order_detail.0.0.242a6368JCxi4R
There are other modules which specifically have an input for voltage
charging and an output for the load.
Can I connect the battery as in the picture? (Charging and load directly
connected to the battery)
Does the battery charge when it's connected to the power or do I have to
break the circuit to the load while charging?
Or do I need a different BMS?
: Moved by Moderator
von pegelwendler (Guest)
Rate this post
useful
not useful
Wouldn't.
Your module doesn't include a protection against discharging below safe
levels.
This one does: https://de.aliexpress.com/item/32930640893.html
Also, I would strongly consider limiting the charge current. Your module
(and mine) state 1A by default. Your battery has 240 mAh and will likely
be fried if you actually pump it with 1A.
If possible, limit the charge current to something way below 1A.
Table for appropriate resitor here:
https://www.reichelt.de/entwicklerboards-ladeplatine-fuer-3-7v-li-akkus-usb-c-1a-debo1-3-7li-1-0a-p291398.html
Personally, I'd go with 70 mA.
Rate this post
useful
not useful
Thank you very much.
Very helpful.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
