EmbDev.net
Forum: µC & Digital Electronics AVR Questions for Uni
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Dogukan D. (deneme)
Rate this post
useful
not useful
I urgently need solutions to these questions. Is there anyone who can
help me?
: Moved by Moderator
von Karl (Guest)
Rate this post
useful
not useful
Dogukan D. schrieb:
> Is there anyone who can help me?
No. Ask your Teacher.
Rate this post
useful
not useful
I really need this.
von Was (Guest)
Rate this post
useful
not useful
Was ist das für ein Englisch?
Rate this post
useful
not useful
I need help with these questions, not comments about my English.
von Was (Guest)
Rate this post
useful
not useful
So sicher nicht.
Lerne lieber Grundlagen.
Rate this post
useful
not useful
I have a very short time to solve these. Please help if you can.
von Heiner (Guest)
Rate this post
useful
not useful
Guess you attended the relevant course at university or school.
So better check your scripts, use your brain - and good luck
By the way - where are you from? The way u ask reminds me of some
politicians.
von Yoyoyo (Guest)
Rate this post
useful
not useful
Whoever has written these questions had a stroke and needs to get into
the hospital at once!
Oder hast du den Kram durch 3 schlechte Onlineübersetzer gewürfelt damit
dein Prof nicht merkt das du betrügst?
von EAF (Guest)
Rate this post
useful
not useful
Ich bin mal nicht so!.
Sorge dafür, dass es Erklärungsnot bei Nachfragen gibt.
Also: Punkt 4 in Anlehnung an......
#include <Streaming.h> // die Lib findest du selber ;-)
Print &cout = Serial; // cout Emulation für "Arme"
// #include <functional>
constexpr size_t N {6};
byte test[N] {1,2,3,4,5,6};
template<typename T>
void reverse(T *begin, T *end)
  end--;
  while(begin<end)
    T temp=*end;
    *end=*begin;
    *begin=temp;
    begin++,end--;
24
25
void setup()
26
27
  Serial.begin(9600);
28
  cout << F("Start: ") << F(__FILE__) << endl;
29
30
31
  for(auto v:test) cout << v << endl;
32
  reverse(test,test+N);
33
  // std::reverse(test,test+N);
34
35
36
37
void loop()
38
39
40
von Norbert (Guest)
Rate this post
useful
not useful
Wer für die Beantwortung von Frage Nummer Eins ernsthaft Hilfe benötigt,
der sollte sich auf Mehlstaub-Allergie untersuchen lassen.
In der Bäckerbranche wird händeringend gesucht…
von stefanus (Guest)
Rate this post
useful
not useful
Simply writing the answers for you does not make sense.
I imagine that you finish your time at the university this way and later
program a piece of code in my next car that drives us directly to death.
No. If you cannot solve this simple work yourself within an hour, you
should fail and either start over learning or leave the university.
von nulltabber (Guest)
Rate this post
useful
not useful
Deine scheiss Tabs kannst du dir irgendwo hinstecken
von helpyourself (Guest)
Rate this post
useful
not useful
von Heiner (Guest)
Rate this post
useful
not useful
@Dogukan D. (deneme)2022-04-15 09:35
Are you still with us??
von Thomas (Guest)
Rate this post
useful
not useful
von EAF (Guest)
Rate this post
useful
not useful
Wo sind se denn?
Die Tabs...
Wo sind se denn?
Siehst du Geister?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
