EmbDev.net
Forum: µC & Digital Electronics Check the Schematic Atmega328P with LoRa
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Mia (Guest)
Rate this post
useful
not useful
can someone check if my Arduino with LoRa Circuit is correct please ? :)
I want to design PCB , wich start just when a one of two Signals  from
J7 come ,
i use OR-Gate with MMBT5551 BJT to connect the GND1 from battery to GND
in my circuit , and then i will send signal with LoRa chip .
Is my design correct ? will my Schematic working well ?
Lora need 100 mA max, uC need about 200 mA max
https://datasheet.lcsc.com/lcsc/1810190020_Changjiang-Electronics-Tech--CJ-MMBT5551_C2145.pdf
: Moved by Moderator
von Mia H. (miaaaa)
Rate this post
useful
not useful
sorry , that is the schematic
von N. M. (mani)
Rate this post
useful
not useful
There ist no complete schematic.
So how can we check?
Do you realy need the 16MHz?
If 8MHz are OK you can remove the hole boost Part and you dont need
Signal conversion between LoRa Module and uC.
By the way...where ist this done?
Edit:New schematic is added
: Edited by User
von Mia H. (miaaaa)
Rate this post
useful
not useful
I add it now here
i need 16MHZ
i will connect it with cabel
von N. M. (mani)
Rate this post
useful
not useful
And a cable makes signal conversion?
von Mia H. (miaaaa)
Rate this post
useful
not useful
RA-02 makes signal conversion and ready to connect directrly with
Arduino( Atmega328p)
von Mia H. (miaaaa)
Rate this post
useful
not useful
von Mia H. (miaaaa)
Rate this post
useful
not useful
Do you mean like that ?
i make new schematic with 3.3 V
von N. M. (mani)
Rate this post
useful
not useful
Nope.
Not with 5V Atmega (see Attachment).
von Mia H. (miaaaa)
Rate this post
useful
not useful
> Nope.
von N. M. (mani)
Rate this post
useful
not useful
Yes, if 16MHz are not needed.
With this Change you dont need the Boost, no Signal Conversion between
LoRa and uC and it is also better for battery mode because of lower
power consumption.
von Mia H. (miaaaa)
Rate this post
useful
not useful
> power consumption.
thank you ,
will my logic with OR-Gate and BJT  working to start up the circuit?
: Edited by User
von Mia H. (miaaaa)
Rate this post
useful
not useful
with 3.3 on reset
von N. M. (mani)
Rate this post
useful
not useful
Your power supply isnt valid with the last changes.
V3 of CH340 needs input voltage in 3V3 Mode. It is no output.
So you have to generate 3V3 from your USB or the battery (see attachment
CH340 or datasheet).
If you need an integrated 3V3 regulator, take a look at the FT232.
I dont think so. It is not very common to switch GND. I would recommend
you to switch supply voltage 3V3 with a highside FET.
Also I would recommend you to put In_A and In_B to a static potential
with a pulldown resistor. Because if the pins are floating there will
happen some magic at the output of the OR-Gate. Perhaps it is also good
to put some C there for better EMI behaveiour.
von N. M. (mani)
Rate this post
useful
not useful
Ok, the FT232 can only deliver 50mA @ 3V3. So you need an external
regulator.
von Mia H. (miaaaa)
Rate this post
useful
not useful
> regulator.
can you give me example ? wich Fet can i use with Logic to startup my
circuit ?
I edit it now
von N. M. (mani)
Rate this post
useful
not useful
I think something like in the attachment. Cant give you a good example
(I am in the train at the moment).
I dont know if you realy need the 300mA...Common types in China Boards
are AMS1117 or MCP1825 or ...
For highside switch take a look into the Forum. There are so many
recommendations. 300mA is not so much for an FET. So a small one SOT23
will do ist.
von Helmut -. (dc3yc)
Rate this post
useful
not useful
I would spend a crystal, even for 8MHz because the internal oscillator
may not be very accurate.
von Mia H. (miaaaa)
Rate this post
useful
not useful
> will do ist.
which P-Fet can working with 3V without drop-down the voltage ?
von r0bm (Guest)
Rate this post
useful
not useful
https://embdev.net/topic/537580?goto=7079156#7079156
von Uskeliye U. (uskeliye46)
Rate this post
useful
not useful
Rate this post
useful
not useful
https://panoramacharter.ltd/
https://19216811.bid/
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
