EmbDev.net
Forum: µC & Digital Electronics STM32F103 math package
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Rudi D. (rulixa)
Rate this post
useful
not useful
calculation time fixcomma for si5351
I have a project with Arduino UNO where the execution time for the line
below is 5,78 ms. The line is part of a Wobbler, which is running with
64 steps only. I awaited 1.28 ms with BluePill. After porting to
STM32F103 see yourself.
si5351.set_freq_manual((fnow) * 100ULL, pll_freq, SI5351_CLK0); //4,5 ms
//bin von BluePill enttäuscht
My expectation was, using BluePill, 5,78 / (72/16) MHz = 1,28 ms. Result
see above.
Only 22% quicker.
I'm using only fixcomma variables.
Any proposals?
Codes available if wanted.
: Moved by Moderator
von noreply@noreply.com (Guest)
Rate this post
useful
not useful
I think, it's not a problem of the math package. Analyze communication
overhead to SI5351
von W.S. (Guest)
Rate this post
useful
not useful
Rudi D. wrote:
> Any proposals?
It looks as if there is no proper setup for the clock. Therefore the
chip runs from only a slow internal RC-oscillator. Another idea is, that
the function "si5351.set_freq_manual" does it's calculations in a very
clumsy way. Or both, slow clock and clumsy algorithm.
W.S.
von ruilxa (Guest)
Rate this post
useful
not useful
Independent on I2C speed 100k or 400k nothing changes.
Still 4,4 ms for the si5351 Command.
Also the time needed for encoder interrupt is very short. If  I set the
interrupt to 5 ms -missing some encoder steps- does not change the 4,4
ms.
I'm familiar with fixcomma in assembler with tiny4313 and wobble
frequencies at max. 70 HZ. DDS Project in RMorg 2014-2015 with AD9850 up
to 30 MHz.
I think this would be a solution, but the si5351 is much more complex
comp. to AD9850. I want to use the si5351 up to  120 MHz. With some
phase mod. to have some sound.
Will see if I have enough drive to step into the si53551 deteils
registers and communication.
von W.S. (Guest)
Rate this post
useful
not useful
> comp. to AD9850.
The SI5351 is a clock-generator based on PLL - it gives only a digital
output. The AD9850 is a DDS - it gives an analog output and needs a low
pass filter on the output.
While the AD9850 is very agile (it only needs to set the phase-offset to
switch it from one frequency to another) the SI5351 needs some time to
settle the VCO and its phase-loops.
Both chips are complex in their own way, but the use of the SI5351 ist
much more complicated compared to the AD9850, because the SI needs a
combination of 2 integer numbers, which give the best approximation to
the desired frequency - while the AD needs only the best value for the
phase increment.
W.S.
von JojoS (Guest)
Rate this post
useful
not useful
is this from some public library? When it was designed for Arduino with
AVR, a common problem is the superfluous usage of type double. With 8
Bit AVR, the calculations were performed as float, but when used with
Cortex-M, expensive double math is used.
von ruilxa (Guest)
Rate this post
useful
not useful
that is good news. I thought all is done with fixcomma.
But how can I interfere?
von JojoS (Guest)
Rate this post
useful
not useful
you could show which lib you have used
von ruilxa (Guest)
Rate this post
useful
not useful
https://github.com/etherkit/Si5351Arduino
#include <si5351.h>               //Etherkit
von JojoS (Guest)
Rate this post
useful
not useful
Obviously, FP math is not an issue in this lib.
The development of this lib looks stale, there was as issue:
https://github.com/etherkit/Si5351Arduino/issues/22
I don't use this chip and cannot help further. It may be a problem of
the pll setting to a new frequency. Or a problem of the I2C transfer,
there was a comment of using a bulk transfer and speeding it up.
Rate this post
useful
not useful
here is the complete code so far. Only 10 wobble steps for time
measurement.
von indeed (Guest)
Rate this post
useful
not useful
> clumsy way.
Indeed.
Da kraeuseln sich einem ja die Nasenhaare.
Rate this post
useful
not useful
der si will ja 1/100 Hz Angaben.
Besser wäre eine Erklärung, warum sich die Haare kräuseln
von Erin (erintse01)
Rate this post
useful
not useful
This is the overview of STM32F103 newly updated.
It includes the clock tree of STM32F103 and more, hope it helps.
https://www.embedic.com/technology/details/stm32f103
von Crust fate (crustfate)
Rate this post
useful
not useful
von Rest K. (restkro67q)
Rate this post
useful
not useful
I guess by using HAL the differences should be minor as it's a deep
abstraction layer over the CMSIS. Usually the StdPeripheral library (or
LL - low level) libraries -which also wrap the CMSIS- have significant
differences between different families.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
