EmbDev.net
Forum: FPGA, VHDL & Verilog How to output ROM data that is loaded from an MIF file on GTKwave?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Mahmoud R. (mahmoud899)
Rate this post
useful
not useful
I am writing a ROM vhdl code and I loaded the ROM with an MIF file. I
wrote a testbench for the ROM and I ran it on GTKWave and there was no
output when specific ROM addresses were selected.
ROM Code (rom.vhdl):
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity rom is
generic(
    addr_width  : integer := 16;
    addr_bits   : integer := 4;
    data_width  : integer := 8
port(
    address     : in std_logic_vector(addr_bits-1 downto 0);
    dataout     : out std_logic_vector(data_width-1 downto 0)
end rom;
architecture behavioral of rom is
    type rom_type is array (0 to addr_width-1) of std_logic_vector(data_width-1 downto 0);
23
24
    signal my_rom : rom_type;
25
26
    -- note that 'ram_init_file' is not the user-defined-name (it is attribute name)
27
    attribute ram_init_file : string;
28
29
    -- "seven_seg_data.mif" is saved in the folder "ROM", then use "ROM/seven_seg_data.mif"
30
    attribute ram_init_file of my_rom : signal is "romdata.mif";
31
32
33
 begin
34
35
    dataout <= my_rom(to_integer(unsigned(address)));
36
37
 end behavioral;
ROM Testbench Code (rom_tb.vhdl):
library ieee;
entity rom_tb is
end entity;
architecture behavioral of rom_tb is
component rom
port(
    address     : in std_logic_vector(3 downto 0);
    dataout     : out std_logic_vector(7 downto 0)
end component;
signal address  : std_logic_vector(3 downto 0);
signal dataout  : std_logic_vector(7 downto 0);
begin
    U0 : rom port map (address, dataout);
    stim_process : process
23
    begin
24
        address <= "0000";
25
        wait for 10 ns;
26
27
        address <= "0001";
28
        wait for 10 ns;
29
30
        address <= "0010";
31
        wait for 10 ns;
32
33
        address <= "0011";
34
        wait for 10 ns;
35
36
        address <= "0100";
37
        wait for 10 ns;
38
39
        assert false report "Reached end of test";
40
        wait;
41
42
    end process;
43
end behavioral;
MIF File (romdata.mif):
% romdata.mif %
% ROM data    %
% data width and total data %
width=7;    % number of bits in each data
depth=16;   % total number of data (i.e. total address) %
    format of the data and address stored in this file
    uns : unsigned, dec : decimal, hex : hexadecimal
    bin : binary, oct : octal
address_radix=uns;  % address is unsigned-type %
data_radix=bin; % data is binary-type %
% ROM data %
content begin
    [0..15] : 0000000;
    0 : 00000000;
    1 : 00000001;
    2 : 00000010;
23
    3 : 00000011;
24
    4 : 00000100;
25
    5 : 00000101;
26
    6 : 00000110;
27
    7 : 00000111;
28
    8 : 00001000;
29
    9 : 00001001;
30
    10 : 00001010;
31
    11 : 00001011;
32
    12 : 00001100;
33
    13 : 00001101;
34
    14 : 00001110;
35
    15 : 00001111;
36
37
end;
What is wrong with the code and what do I need to do to be able to
output what is stored in the memory addresses?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
