EmbDev.net
Forum: µC & Digital Electronics clear the receive buffer
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Gilles Patrick T. (gillespatrick_t)
Rate this post
useful
not useful
I'm using the HAL_UART_Receive_IT function on stm32f303re to recieve
data. After each use I want to delete the content of the receive buffer
so that the next data that will arrive will start at the first index of
the array. Is there a function to delete the content of the receive
buffer of the function HAL_UART_Receive_IT(&huart, buffer,
sizeofbuffer)?
: Moved by Moderator
Rate this post
useful
not useful
the receive buffer of the HAL_UART_Receive_IT behaves like a ringbuffer,
the new data is stored starting from the index after the previous
received data
von Peter D. (peda)
Rate this post
useful
not useful
Exactly, what I would expect.
The HAL should provide two functions, one to see, that at least one byte
was available and another to read out a byte from the FIFO.
Manipulating the internal FIFO structure should be avoided in general.
It may cause hassle.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
