EmbDev.net
Forum: µC & Digital Electronics 100W LED Arduino
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Frederik (Guest)
Rate this post
useful
not useful
Hello,
I'm currently trying to build some Uplights/Spotlights for my Light
Show. Therefore I need to control some High Power LEDs with an arduino.
I had the idea to buy a server power supply as they're quite cheap (I
don't want to spend more than is really needed). It will act as the main
power source for several other light effects. I want to step up this
voltage to the required 34v for the LED. To do this I want to use some
simple Step-Up Converters with current limiting. My question is how I
can control/dimm the LED. I think dimming could be archieved via a PWM
signal. Are there any Problems I havent thought of? What transistors do
I have to use? I never really learned anything about transistors and I
dont know how to find a suitable one or what resistor to use at its
base.
https://www.amazon.de/Step-Converter-Boost-Modul-Step-up-Boost-Wandler-Konstantstrom-Netzteilmodul/dp/B097JRRBZ5/ref=sr_1_12_sspa?keywords=dc+dc+converter&qid=1660499973&sr=8-12-spons&psc=1&smid=A16GYQDD9HBXX&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzU0hCRjQ4V1NDRjhUJmVuY3J5cHRlZElkPUEwNTk5NDM1WllBM1M5TEpHRlNCJmVuY3J5cHRlZEFkSWQ9QTAyNTMxNjYxUDA3SVBQRUVKWDU3JndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Thanks a lot
Frederik
von Falk (Guest)
Rate this post
useful
not useful
A popular wish.
Yes and no. A step up works, but it must use current control instead of
voltage control, since LEDs need an external current limit.
Via the enable pin of the step up controller.
As a rookie, there are plenty ;-)
> What transistors do
> base.
And you want to build a LED power supply? Good luck.
My advive. Buy some proper LED power supplies, they come with reasonable
prices. Get some with the correct input voltage, so you can use you
server PSU.
Rate this post
useful
not useful
I'm now ready to assemble one for testing. I bought a Dell L1100A-S0
1100W for quite cheap. I'm now having a problem as the connector doesn't
have 6 tiny pins but 8. It therefore isn't a normal common slot
connector. This is why I don't know how to wire or bridge the contacts
to turn it on. If anybody can help me I'd be happy.
Thanks a lot
Frederik
von H. H. (Guest)
Rate this post
useful
not useful
Rate this post
useful
not useful
I already tried that but mine doesn't go into that false mode at the
beginning. I connected the 4th pad with the other 4th pad. After
connecting the 3rd and the 4th pad on its underside, the led turns
yellow and I have to unplug the power supply as it doesn't do anything.
Not shure what he did differnt.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
