EmbDev.net
Forum: µC & Digital Electronics USB-C Pinout for power adapter
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von UlrichMuc (Guest)
Rate this post
useful
not useful
The UCB-C plug of my power adaptor for Star LapTop notebook is broken.
I bougt a 65 W Lenovo power supply that works nicely, but I want to
repair
the old one as a backup.
The old plug has got a cable with three wires: black for ground,
white for VBUs, blue for configuration.
I guess I need to connect the black wire to A1, A12, B12, and B1.
The white one to  A4, A9, B4, and B9.
The blue one to A5 and B5.
Now my questions:
Is this correct?
Do I need to add any resistors?
The only plug I found that provides access to the pins needed is shown
in the picture attached.
Thanks for any advice,
ulrich
: Moved by Moderator
von Michael D. (mike0815)
Rate this post
useful
not useful
Ich habe die Pinbelegung gleich gefunden...
von Ulrich L. (ulrichmuc)
Rate this post
useful
not useful
"Ich habe die Pinbelegung gleich gefunden..."
Diese Antwort ist wenig hilfreich. Offenbar kenne ich die Pinbelegung.
Meine zweite Frage (Widerstand?)wird nicht beantwortet.
Rate this post
useful
not useful
evtl. könnte dieser Beitrag weiterhelfen:
https://www.elektronik-kompendium.de/sites/com/2009021.htm
HEADLINE:
EMCA - Electronically Marked Cable Assembly
von MATHU Y. (mathuyaar76)
Rate this post
useful
not useful
Hello. That's not so easy. If you connect only VBUS and GND your laptop
will (probably) not charge. That's because USB C can provide a wide
range of voltages (from 5V to 20V, up to 100W iirc). To do so the host
and the device negotiate the appropriate voltage through what's known as
USB PD (power delivery). The Vbus starts at 5V and then the laptop asks
for the most appropriate voltage (usually close to 20V). Several pins on
the connector are involved in USB PD, so the easiest and safest way to
restore your laptop is to solder another USB C connector. If your laptop
comes with more than a USB C connector you can charge it via the
other(s).
Rate this post
useful
not useful
@MATYU
You write:
You misunderstood the problem. There is no problem at all with the
laptop.
The problem is, that the USB-C plug of the power adaptor is broken and
the question was, how to connect the three wires that go out of the
power adaptor
to a new USB-C plug. Wired plugs, I have seen only with two wires.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
