EmbDev.net
Forum: FPGA, VHDL & Verilog how to fix collision reset problem in ethernet mac table
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Melik S. (Company: Kocaeli Universty) (melik)
Rate this post
useful
not useful
In a project I'm working on an FPGA, I'm converting a 48-bit MAC address
to 16-bit using the Hash algorithm. RAM size is 2^16 bits and I have 8
ETHERNET ports. I am using the resulting hash as ramin address port.
Each ethernet port has multiple source addresses. The questions start
here.
1) example: A packet with source address A was received from ethernet
port 8. After passing the 48-bit A source mac address through the hash
algorithm, the 16-bit X ram address is formed. When going to the B ram
address, the 1st port information -> "10000000" is written.
 A packet with source address B arrived from Ethernet port 1. After
passing the 48-bit B source mac address through the hash algorithm, the
16-bit X ram address is formed. Going to B ram address, 1st port
information -> "10000001" is written.
Currently, if a destination MAC address with the same X ram hash address
comes in, it will be forwarded to both port 8 and port 1.
Is this operation correct or how can it be done with another operation?
2) Since there is no RAM reset process in FPGA, how can I periodically
delete the MAC Table addresses I wrote to the RAM?
von Duke Scarring (Guest)
Rate this post
useful
not useful
I would use a finite state machine (FSM) or that.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
