EmbDev.net
Forum: µC & Digital Electronics Manipulation of json
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Test (Guest)
Rate this post
useful
not useful
Hello,
I have a Json string which looks like this
[[2,3],[5,6]]
I want to read it in an array and add one pair [7,8].
End result should be this
[[2,3],[5,6],[7,8]]
How can I do this?
: Moved by Moderator
von DerEinzigeBernd (Guest)
Rate this post
useful
not useful
Test schrieb:
> How can I do this?
With software.
von Testr (Guest)
Rate this post
useful
not useful
Sorry forget the information...it's in esp8266 code
I need this in an Arduino code..
von Hannes J. (Company: _⌨_) (pnuebergang)
Rate this post
useful
not useful
von Stefan F. (Guest)
Rate this post
useful
not useful
von DPA (Guest)
Rate this post
useful
not useful
Hannes J. schrieb:
> https://stedolan.github.io/jq/manual/
I guess that won't run on an esp8266. But anyway, here is an example for
sh:
echo [[2,3],[5,6]] | jq -c [.[],[7,8]]
von Sebastian (Guest)
Rate this post
useful
not useful
You can write a simple JSON parser that does just that. Or you use a
general JSON parsing library and construct your data structure with it.
I guess adding the additional pair does not require any JSON business.
KR, Sebastian
von J. S. (jojos)
Rate this post
useful
not useful
with ArduinoJson Lib: https://arduinojson.org/
von Test (Guest)
Rate this post
useful
not useful
Hello i tried it
#include <iostream>
#include "ArduinoJson.h"
int main() {
  StaticJsonDocument<300> doc;
  char json[] =
      "[[48.756080,2.302038],[48.756080,2.302038]]";
  DeserializationError error = deserializeJson(doc, json);
  if (error) {
    std::cerr << "deserializeJson() failed: " << error.c_str() << std::endl;
    return 1;
  double longitude = doc[0];
  // Print values.
24
    std::cout << longitude << std::endl;
But the output is 0. WHat is wrong??
von J. S. (jojos)
Rate this post
useful
not useful
double longitude = doc[0][0];
https://wokwi.com/projects/347340486773572179
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
