EmbDev.net
Forum: FPGA, VHDL & Verilog running a simulation with microblaze
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von pete (Guest)
Rate this post
useful
not useful
I am trying to simulate a micro blaze microprocessor demo design with
ram and ports in Modelsim. For XSIM in Xilinx Vivado environment it
allows to synthesize and implement. My problem is to start the
simulation:
I have exported the scripts from Vivado and got a folder exportsim /
modelsim, where I expected a do file to be used with ModelSims TCL
window.
In fact there is a script with extension *.sh wich I do not know how to
start
The readme says: "run ./demo.sh" but this does not work.
Leaving away the . or changing \ also has to result.
Anyone has an idea how to start this script?
It looks like this:
# Script info
echo -e "demo.sh - Script generated by export_simulation (Vivado v2021.1 -id)\n"
# Main steps
run()
  setup
  compile
  simulate
# RUN_STEP: <compile>
compile()
  source compile.do ..
So there are some known commands, but i never had used an sh before.
From a search I found that this might by a bash script and can be
executed by "exec bash" but i did not get it running.
So far I know this is unix shell. Is that correct, that Vivado exports
only for unix style?
Ideas welcomed.
von Duke Scarring (Guest)
Rate this post
useful
not useful
Looks like TCL-script for me...
von pete (Guest)
Rate this post
useful
not useful
Forgot to mention: I am using Windows only and Vivado and ModelSim both
installed on the Win PC / Win10.
From another webpage I picked this:
Modelsim runs TCL. Bash would need to be handed over to the OS. tcl has
an "exec" command that passes instructions to the OS.
So how would be the correct phrase to run the simulation from the
>ModelSIM prompt?
How can i execute it?
ModelSim does not accept the code
./demo
# invalid command name "./demo"
do demo
# Cannot open macro file: board
do demo.sh
# -e demo.sh - Script generated by export_simulation
# ** Error: invalid command name "run()"
# Error in macro ./demo.sh line 36
# invalid command name "run()"
#     while executing
# "run()"
Rate this post
useful
not useful
von Broccoliliving B. (Company: word wipe) (broccoliliving)
Rate this post
useful
not useful
> Try exec:
> https://www.tcl.tk/man/tcl8.5/tutorial/Tcl26.html https://eggycar.net/
Thanks for your guidance, this is exactly what I was looking for. thank
you very much
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
