EmbDev.net
Forum: FPGA, VHDL & Verilog Vhdl project: mini-router
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Luciana (luciana)
Rate this post
useful
not useful
I have a project about design and implementation of a mini router. I' ll
share the source code I wrote and the design in Vivado. Can someone
expalin why the design is organized in this way? Is it correct?
-- Libreria
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
-- Entity
entity mini_router is
   port (
         clk       : in  std_logic;
         reset     : in  std_logic; -- Reset asincrono attivo basso
     data1     : in  std_logic_vector(9 downto 0);
     req1      : in  std_logic;
     grant1    : out std_logic;
         data2     : in  std_logic_vector(9 downto 0);
     req2      : in  std_logic;
     grant2    : out std_logic;
     data_out  : out std_logic_vector(7 downto 0);
23
     valid     : out std_logic
24
25
end entity;
26
27
28
29
-- Architecture
30
31
architecture arch of mini_router is
32
33
-- Segnale per controllo req
34
   signal request    : std_logic_vector (1 downto 0);
35
36
-- Segnali per controllo bit di parità
37
   signal a          : std_logic; -- '1' se A < B altrimenti '0'
38
   signal b          : std_logic; -- '1' se A = B altrimenti '0'
39
   signal c          : std_logic; -- '1' se A > B altrimenti '0'
40
41
-- Segnale per applicazione dell'algoritmo Round Robin
42
   signal r          : std_logic;
43
44
45
-- Comparatore per controllo sui bit di parità
46
  component comparator is
47
     port (
48
            A           : in std_logic_vector(1 downto 0);
49
            B           : in std_logic_vector(1 downto 0);
50
            A_less_B    : out std_logic;
51
            A_equal_B   : out std_logic;
52
            A_greater_B : out std_logic
53
54
   end component;
55
56
57
 begin
58
59
  request     <= req1&req2;
60
61
   COMPARATORE: comparator
62
    port map (
63
      A           => data1 (1 downto 0),
64
      B           => data2 (1 downto 0),
65
      A_less_B    => a,
66
      A_equal_B   => b,
67
      A_greater_B => c
68
69
70
 mini_router: process(clk,reset)
71
72
 begin
73
74
   if reset = '0' then
75
       data_out    <= (others => '0');
76
     grant1      <= '0';
77
     grant2      <= '0';
78
     valid       <= '0';
79
     r           <= '0';
80
81
82
   elsif rising_edge(clk) then
83
84
 -- Un solo req è alto
85
      if request = "10" then
86
87
       data_out <= data1(9 downto 2);
88
         grant1   <= '1';
89
       grant2   <= '0';
90
       valid    <= '1';
91
92
   elsif request = "01" then
93
94
         data_out <= data2(9 downto 2);
95
         grant1   <= '0';
96
       grant2   <= '1';
97
       valid    <= '1';
98
99
-- Entrambi i req sono bassi
100
     elsif request = "00" then
101
102
103
      grant1   <= '0';
104
        grant2   <= '0';
105
        valid    <= '0';
106
107
-- Entrambi i req sono alti
108
   elsif request = "11" then
109
110
-- Il link 1 ha maggiore priorità
111
        if c='1' then
112
113
114
           grant1    <= '1';
115
         grant2    <= '0';
116
         valid     <= '1';
117
118
-- Il link 2 ha maggiore priorità
119
        elsif a='1' then
120
121
122
         grant1    <= '0';
123
         grant2    <= '1';
124
         valid     <= '1';
125
126
 -- Data conflict
127
        elsif b='1' then
128
129
-- Applicazione dell'algoritmo Round Robin
130
           if r = '0' then
131
132
133
              grant1    <= '1';
134
            grant2    <= '0';
135
            valid     <= '1';
136
              r         <= '1';
137
138
           else
139
140
141
          grant1    <= '0';
142
            grant2    <= '1';
143
            valid     <= '1';
144
              r         <= '0';
145
146
           end if;
147
148
        end if;
149
150
      end if;
151
152
    end if;
153
154
  end process;
155
156
end architecture;
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
