EmbDev.net
Forum: Analog Circuits The Arrhenius constants α and β
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Marouen B. (marouen_b)
Rate this post
useful
not useful
Hello together,
How can i get the Arrhenius constants α and β from the information
the Simulink® library of the battery block?
: Moved by Moderator
Rate this post
useful
not useful
Hello together,
the Simulink® library of the battery block?.
von Rick M. (rick-nrw)
Rate this post
useful
not useful
Hi Guy!
It is Christmas!
Cherish this time!
von UnknownUser (Guest)
Rate this post
useful
not useful
Well,
the ln is nothing else than the logarithm to the base e.
But if a logarithm has the same argument as its base, that is equal to 1
by definition.
That means, divide K(T,ref) and R(T,ref) to switch it on left side.
Now multiplicate with ln (left and right side. That means for right side
follwing facts:
ln^(e) = 1
1 × your alpha oder beta term. The alpha and beta part comes now out /
down from exp. part.
For left side you have to consider the ln calculation rules:
ln(R/R(T,ref)).
The Temperature terms on the right side can you easily handle with a
division and you will get alpha and beta free.
I hope that helps you.
Rate this post
useful
not useful
thanks for the feedback though
that wasn't what I meant because R(T) and K(T) are unknown.
The only question was how I alpha and beta from the information
the Simulink battery block library could get
Rate this post
useful
not useful
Ah ok,.. for my understanding:
You should find out the R and K value over a thereotical estimation or
lab trials. For my opinion: alpha and beta are open values which are
maybe not further defined in Simulink. Well, more details are given in
literature, or Simulink Help Section for a definition  of different
battery material setups? But, i dont know it sure.
von Ute, Papa Ute! (Guest)
Rate this post
useful
not useful
Marouen B. schrieb:
> (The only question was how I alpha and beta) x -1 = Fatal error
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
