EmbDev.net
Forum: FPGA, VHDL & Verilog SimulationVS real time
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Daniel C. (Company: NON) (r_daniel)
Rate this post
useful
not useful
What are the reasons that the system I designed will work exactly in the
simulation, at the same time you will not see errors, but after burning
the system will not work on the board.
What do you start looking for in the code at such a stage?
von Gustl B. (-gb-)
Rate this post
useful
not useful
There can be plenty of errors you will not see in simulation.
Your simulation looks like something with SPI or I2C. So you have to
build the external slave device in the testbench as well. With correct
timing and startup configuration.
Often some signals just don't match the testbench. Clock frequency
higher or lower, ...
But you may show more code. Just upload all your HDL and the testbench
so we can simulate as well.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
The usual way to get there is by ignoring the warnings and infos
reported by the toolchain when generating the bitstream file.
The report files: are there any obscure warnings or infos? And the RTL
schematic: does the synthesizers schematic look like your idea?
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
