EmbDev.net
Forum: FPGA, VHDL & Verilog Quartus Prime Verilog error Node "X" is missing source
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Johan (kwistjhp)
Rate this post
useful
not useful
Dear all,
I have a newbie question on Verilog. I am using Quartus Prime (Lite
Edition) to write some Verilog code for my Arduino MKRVIDOR 4000
(Arduino board with FPGA); my goal is to get communication between the
CPU and FPGA working using Florian Zachs's JTAG interface
(https://github.com/HerrNamenlos123/JTAG_Interface). I use a standard
MKRVIDOR4000_top.v template (containing all the definitions of the I/O
signals etc.) that includes user.v that has my own code. The template is
attached for reference but the error is in the code below.
What I can't get to synthesize, for reasons I don't understand, is to
change behaviour of an input-output mapping between two digital pins
shared between the CPU and FPGA based on the contents of a register that
can be written to using the JTAG interface. Either the FPGA copies the
digital signal it receives on D5 to D6, or it inverts the signal. I want
to change this behaviour using a command issued via JTAG.
This is my code:
// define register used to communicate from microcontroller to FPGA using JTAG interface
reg [31:0] COMMAND;
// 1-bit registers
reg spike_in;
reg spike_out;
reg state_var;
// wOSC_CLK is the clock input signal used by the JTAG interface
JTAG_Interface  b2v_inst1(
 .iCLK(wOSC_CLK),
 .iREAD_0(COMMAND)
// either copy or negate input pin D[5] to output pin D[6]
always @(posedge wOSC_CLK)
begin
 spike_in <= bMKR_D[5];
 spike_out <= (state_var == 1'b1) ? spike_in : ~spike_in;
 bMKR_D[6] <= spike_out;
end
// react on JTAG change of COMMAND register (only msb is relevant)
24
always @(COMMAND)
25
begin
26
 state_var <= COMMAND[31];
27
end
Quartus doesn't accept this code, complaining "12009 Node "spike_out" is
missing source". I don't understand why this is the case, although I
assume that the conditional assignment to spike_out is to blame, because
the circuit synthesizes when I make this unconditional on state_var. I
hope someone can enlighten me why this is the case and how the desired
behaviour could be achieved.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
