EmbDev.net
Forum: FPGA, VHDL & Verilog Pipeline circuit
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Pietro (sender02)
Rate this post
useful
not useful
Hi, I need to write the VHDL code of the following pipeline circuit:
The circuit receives 2 control signals and two input signal of n bit and
it does the follow operations:
A+B if c0=c1=0
-A-B if c0=c1=1
A-B if c1=0 and c0=0
-A+B if c1=1 and c0=0
I have written the following diagram circuits but I don't know if I need
to put registers between the two adders.
Thank you for the answers.
: Moved by Moderator
von Gustl B. (-gb-)
Rate this post
useful
not useful
What pipeline?
Try ChatGPT:
Input:
A+B if c0=c1=0
-A-B if c0=c1=1
Answer:
To implement this circuit in VHDL, you will need to use an if-else
statement to determine the output based on the values of the control
signals c0 and c1. Here is an example of how you can write the VHDL code
for this circuit:
library ieee;
use ieee.std_logic_1164.all;
entity pipeline_circuit is
  port (
    c0 : in std_logic;
    c1 : in std_logic;
    A : in std_logic_vector(n-1 downto 0);
    B : in std_logic_vector(n-1 downto 0);
    result : out std_logic_vector(n-1 downto 0)
end pipeline_circuit;
architecture behavioral of pipeline_circuit is
begin
  process(c0, c1, A, B)
  begin
    if (c0 = '0' and c1 = '0') then
      result <= A + B;
    elsif (c0 = '1' and c1 = '1') then
      result <= -A - B;
    elsif (c1 = '0' and c0 = '0') then
23
      result <= A - B;
24
    elsif (c1 = '1' and c0 = '0') then
25
      result <= -A + B;
26
    else
27
      result <= (others => 'Z');  -- default value for result
28
    end if;
29
  end process;
30
end behavioral;
This code defines an entity called "pipeline_circuit" with four inputs
(c0, c1, A, and B) and one output (result). The output is determined by
the values of the control signals c0 and c1 using the if-else statement
in the process.
I hope this helps! Let me know if you have any questions.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
