EmbDev.net
Forum: FPGA, VHDL & Verilog Verilog circuit
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Mattia (piratajack2003)
Rate this post
useful
not useful
i need to write this circuit in verilog.
Thanks.
von Gustl B. (-gb-)
Rate this post
useful
not useful
Well ... how are a, b and c connected at the bottom of the MUX? The left
input is b, then a and right is c. So 000 ... 111 is a combination of b,
a, c.
In VHDL it would be:
signal sel := std_logic_vector(2 downto 0);
begin
sel <= b & a & c;
with sel select y <=
   a and b when "000",
         c when "001",
   a and b when "010",
       '1' when "011",
   a and b when "100",
       '0' when "101",
   a and b when "110",
   a xor b when "111";
And now ask ChatGPT to translate this in Verilog:
Question:
Translate
begin
sel <= b & a & c;
   a and b when "000",
         c when "001",
   a and b when "010",
       '1' when "011",
   a and b when "100",
       '0' when "101",
   a and b when "110",
   a xor b when "111";
to Verilog.
Answer:
reg [2:0] sel;
always @* begin
  case (sel)
    3'b000, 3'b010, 3'b100, 3'b110: y = a & b;
    3'b001: y = c;
    3'b011: y = 1'b1;
    3'b101: y = 1'b0;
    3'b111: y = a ^ b;
  endcase
end
assign sel = b & a & c;
von Magnus M. (magnetus)
Rate this post
useful
not useful
> Thanks.
Wow... nice to know!
So GO FOR IT!
von Vancouver (vancouver)
Rate this post
useful
not useful
Gustl B. wrote:
> Answer:
Ouch... obviously chatGPT needs to learn a bit more about the
differences between VHDL and Verilog.
von Jayanth (jayanth)
Rate this post
useful
not useful
module mux(input b,a,c,
            output reg y );
always@(b,a,c)
begin
    if(!b)
    assign y=c;
    else if(b)
    begin
        assign y=a;
        if(a==1 && c==1)
        assign y=1'b0;
    end
end
endmodule
this code was successfully executed on xilinx vivado
testbench
module tb;
reg b,a,c;
wire y;
mux uut(b,a,c,y);
initial
begin
b=1'b0; a=1'b0; c=1'b0;
#10 b=1'b0; a=1'b0; c=1'b1;
#10 b=1'b0; a=1'b1; c=1'b0;
#10 b=1'b0; a=1'b1; c=1'b1;
#10 b=1'b1; a=1'b0; c=1'b0;
#10 b=1'b1; a=1'b0; c=1'b1;
#10 b=1'b1; a=1'b1; c=1'b0;
#10 b=1'b1; a=1'b1; c=1'b1;
#20 $finish;
end
endmodule
sorry if am too early😅
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
