EmbDev.net
Forum: µC & Digital Electronics AVR ATMega328PB clock capacitors
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Thomas (thomas427)
Rate this post
useful
not useful
Hello,
Currently I try to calculate the necessary capacitors for a 7.3728 MHz
crystal supposed to be external clock source on an ATMega328PB. The
crystal (ECS-73-18-23B-JTN) according to its datasheet requires 18 pf
load capacitance. The µC datasheet gives formulas to calculate the value
of the external capacitors. In addition it gives the internal
capacitance of the XTAL1 and XTAL2 pins. What puzzels me, different
capacity are given for XTAL1 and XTAL2, 18 pF and 8 pF, respectively.
Does this mean I don't need an external capacitor on XTAL1, whereas on
XTAL2 I would need 10 pF? Assuming stray capacitance of 4 pF, the
maximum capacitance of 22 pF is already reached at XTAL1?
Many thanks for your help!
Regards, Thomas
von Gerhard O. (gerhard_)
Rate this post
useful
not useful
It is really not that critical. I usually look up the load capacitance
in the crystal data sheet and allow a few pF for wiring capacitance.
If the datasheet specifies 18pF, I would choose 15pF and it will work
with compatible crystals.
Generally it is a good idea to follow the recommendations in the device
data sheet and app notes regarding uC crystal oscillator considerations,
If you need really precise frequency, you'll need to consider
calibrating the circuit with a trimmer capacitor.
However, in normal uC applications it is not really required. BAUD rates
are usually not exact due to divider frequency errors and it makes more
sense to choose such crystal frequencies that allow exact divider
ratios.
Regards,
Gerhard
Rate this post
useful
not useful
Hi Gerhard,
thanks for quick answer!
I chose 7.3728 MHz indeed to match to BAUD rates for serial connection.
The system is supposed to be supplied by 3 V, which allows freqency of
the ATmega328PB up to 10 MHz.
So I should not consider internal capacity of the pins at all? Formulas
in the datasheet and in AN2519 request to do so...
Regards, Thomas
Rate this post
useful
not useful
Thomas,
In my experience it is not worth the effort. Allowing 2-4pF for wiring
and internal parasitic capacitance is usually adequate. As I mentioned
before, I allow about 3pF for this and had never ever any issues. Unless
you are required providing detailed design documentation, it is
overkill. Besides, crystals have tolerances and unless you measure
crystal operational parameters, you would be just spinning your wheels.
If your crystal connections to the uC pins are as short and direct as
practical, you are done. It is usually a good idea to put the load caps
as close as practical to the oscillator pins using adequate trace width,
as much of the oscillator operation RF current passes through them. The
traces to the crystal can be as thin as convenient to minimize parasitic
wiring capacitance. Also avoid groundplanes on the other side or
internal (multilayer) between crystal pins and load caps. But the
reality is not as critical. The AVRs are quite cooperative when it comes
to implementation.
Just pay attention, what the datasheet specifies and match a crystal to
those requirements and allow for wiring parasitic capacitance.
Regards,
Gerhard
: Edited by User
Rate this post
useful
not useful
Hello Gerhard,
once again many thanks for prompt and very valuable information!
I will try 15 pF, as on other places on the PCB they are used anyhow.
Best regards,
Thomas
Rate this post
useful
not useful
Hello Thomas,
You are welcome. With 15pF you will be in the sweet spot.
Keep also in mind, that the internal functioning of the oscillator
depends on those capacitors more than the crystal. The crystal
manufacturer uses the specified load capacitance to calibrate the
crystal parameters.
Depending on the gain of the oscillator stage and the equivalent crystal
series resistance you will find, actually, that the circuit will operate
over a wide range of C values (10-50pF). But the crystal accuracy and
adherence to the stated crystal parameters will only apply at an actual
nominal load capacitance. This is normally hard to achieve in the
reality.
Keep also in mind, that typical computer crystals have a manufacturing
tolerance of 20 to 50ppm. With a series or variable trim capacitor on
the oscillator input side, one can exactly calibrate the frequency
within the possible range.
Be also aware, that crystals are made and calibrated to either oscillate
in the so called "fundamental mode" or "third" or "fifth" order overtone
mode. At frequencies under 25MHz most crystals are intended to oscillate
in fundamental mode, although most crystals will oscillate in a suitable
circuit also at least in third overtone at approximately three times the
fundamental frequency. Overtone crystal oscillator circuits can be more
critical and difficult to "tame" and require careful adherence to proper
design practice and construction and careful testing.
(You may want to look for further information on the Internet. There is
tons of information).
Regards,
Gerhard
Rate this post
useful
not useful
Hi Gerhard,
The application is in my opinion not particularily critical regarding
frequency. It is supposed to communicate to another device (home
ventilation) over RS-232 serial connection at 9600 BAUD. At first I
considered using the internal oszillator with calibration or a ceramic
resonator, but chose the quartz crystal to be able to absorb as much as
possible timing error on the other side by providing a reasonably
accurate frequency on my side. With the crystal and the 15 pF load
capacitors I hope to achieve this goal with plenty of margin.
Best regards, Thomas
: Edited by User
von Jörg W. (dl8dtl) (Moderator)
Rate this post
useful
not useful
Thomas wrote:
> What puzzels me, different capacity are given for XTAL1 and XTAL2, 18 pF
You're looking at the specification of the 32 kHz crystal oscillator.
Look a couple of chapters before, for the "low power crystal
oscillator", they specify 6 pF for both pins there.
So with an assumed additional 4 pF on both pins, you end up with 10 pF
per pin plus your intended 15 pF capacitors, total of 25 pF per pin. As
these 2 x 25 pF are in series, that results in 12.5 pF overall load.
You'd like to have 18 pF … I'd rather pick 22 pF.
Overall clock accuracy is usually not such a big issue (unless you want
to run a watch), but with the load capacitance too much off, you risk
the oscillator not starting reliably.
Rate this post
useful
not useful
Hi Jörg,
thanks for this remark.
I checked again in ATMega328PB complete data sheet and downloaded also
most recent issue from Microchip website.
In chapter 11.3, Low-Power Crystal Oscillator, there is Table 11-3,
providing those different 18 pF and 8 pF values for the XTAL pin
capacity. What is strange, the top left cell of this table says "32 kHz
Osc. Type", so indeed it seems this is valid for the low-frequency
oscillator. So I assume meanwhile it is a typo in the document.
In which document / issue did you find the 6 pF?
Regards, Thomas
Rate this post
useful
not useful
OK, Microchip first returned me the "A" revision of the datasheet.
Indeed, revision "C" has 18 / 8 pF (and still the typo with the "32 kHz"
in the top left corner of the table).
So with 15 pF + 4 pF stray capacitance, you end up with 37 pF in series
with 27 pF, resulting in a total of 15 pF load for the crystal. I guess
that's good enough given the remaining uncertainties.
Rate this post
useful
not useful
So it seems everybody agrees on 15 pF for both external load capacitors,
I will give them a try! In case it doesn't work I will come back with
more questions...;-)
Many thanks and best regards,
Thomas
Rate this post
useful
not useful
You could of course also make them asymmetric: 22 pF at XTAL2, and 12 pF
at XTAL1.
I guess both will work.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
