EmbDev.net
Forum: FPGA, VHDL & Verilog AXI stream FIFO
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Stanley (hmscosgrove)
Rate this post
useful
not useful
I am a newbies in VHDL, and currently still learning, could anyone
kindly advise how i can start coding VHDL on Vivado a FIFO using AXI
stream that receive a data-in with 64 Bytes containing hexadecimal :
0xEEFFAAFFAAFFAAFFAAFFAA......
Do i need a Finite state machine to start with ? Pls advise, thanks in
advance..
Stanley
von Gustl B. (-gb-)
Rate this post
useful
not useful
There are details missing:
AXI datawidth, desired FIFO depth, ...
You may use the Xilinx FIFO component. It comes free with VIVADO.
Rate this post
useful
not useful
thx for the reply, T byte =64, fifo depth =32, yes i am aware Vivado can
configure FIFO AXI steam, is there any website or tutorial that show
this?
Pls reply soon, thanks. cosgrove.
von Gustl B. (-gb-)
Rate this post
useful
not useful
Did you search for more information?
If yes, then you must have stumbled across the userguide:
https://docs.xilinx.com/v/u/en-US/pg080-axi-fifo-mm-s
von Broccoliliving B. (Company: word wipe) (broccoliliving)
Rate this post
useful
not useful
> https://docs.xilinx.com/v/u/en-US/pg080-axi-fifo-mm-s https://wordwipe.io
Thanks for your guidance, this is exactly what I was looking for.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
